Author Topic: Cowl plenum air cleaner, cold air induction, etc  (Read 66131 times)
Re: Cowl plenum air cleaner, cold air induction, etc
« Reply #15 on: September 24, 2012, 05:02:35 AM »
I had Jim Webb check the cowl plenum duct screws in his red '67 rally sport Z-28. His screws look pretty
much the same as Paul Lasiter's although Paul's have four tiny bumps in a line across the head of the screw
and it looks as though Jim's might only have two bumps. There are no other markings on the screws.
« Reply #16 on: June 16, 2013, 05:36:35 AM »
The diameter of an original, authentic cowl plenum air cleaner lid is 16.75".
« Reply #17 on: June 16, 2013, 05:39:11 AM »
The cowl plenum air cleaner base is 16" across, from the outer edge of the top lip on one side to the same point on the other side.
« Reply #18 on: June 16, 2013, 05:40:23 AM »
Here's a look at the underside of the correct lid.
« Reply #19 on: June 16, 2013, 05:44:44 AM »
Here's a closer look at the groove that the top lip of the air cleaner base rides in. There is a very similar
looking lid that you will see at swap meets that is close to the same size (around 17" dia) that has rubber
in the groove. Don't be fooled into buying it. It won't fit on an original GM cowl plenum air cleaner base.
motorman
« Reply #20 on: June 30, 2013, 12:16:26 AM »
this type air cleaner was originally supplied for the Z-11 impala drag cars.
new Camaros owned 68 and 69 Z-28. new Corvettes owned 59,62,63,64,65,66,97,99 02,05 and 08. retired race engine builder, former NASCAR tech inspector
motorman
« Reply #21 on: June 30, 2013, 12:27:01 PM »
also was used on the 63 NASCAR impalas with the "mystery" engine at daytona
« Reply #22 on: June 30, 2013, 10:06:36 PM »
Yes, you're right. 1963 was the first use by Chevrolet for this style of air induction. The W-series (409 style) 427 Z-11
engine used a modestly different looking cowl plenum air cleaner than the MKII "Mystery Motor" Impalas used at Daytona.
1109RWHP
« Reply #23 on: July 01, 2013, 04:20:48 AM »
Has anyone tested the power gain from an open element filter to a cowl induction setup? Just curious if it actually was a benefit.
« Reply #24 on: July 01, 2013, 05:09:10 AM »
There's no doubt it's a benefit but I haven't seen published figures that show what the horsepower gain was.
There would be more benefit on a course with longer straights where a car sustained higher speeds for longer
time (Daytona and Sebring) than there would be for shorter tracks with slower speeds.
MO
« Reply #25 on: July 02, 2013, 02:48:18 AM »
If it didn't work better, they wouldn't still be using it in NASCAR.
motorman
« Reply #26 on: July 02, 2013, 07:20:36 PM »
you gain 1% in HP for every 10 degrees you lower the intake air temp
motorman
« Reply #27 on: July 02, 2013, 07:24:05 PM »
also those systems cause air turbulence around the carb air bleeds unless you use the L-88 screen on top of the carb to straighten out the air flow if you run without a air filter
« Reply #28 on: July 03, 2013, 02:00:09 AM »
That's a good tip. Thanks.
« Reply #29 on: September 01, 2013, 06:15:28 AM »
If someone is needing a cowl plenum air cleaner for their Trans-Am Camaro or street car, there's one for sale on ebay right now with a buy-it-now of $3,000.
http://www.ebay.com/itm/1967-1968-Z28-Camaro-Trans-Am-Cowl-Plenum-Air-Cleaner-SCCA-Smokey-Yunick-/121168600120
