Author Topic: Engine painting poll  (Read 28184 times)
NoYenko
« on: August 12, 2012, 05:56:38 PM »
I was at a car show with my 70 chevelle and someone commented on my by pass should not be painted. That didn't really bother me but it brought up a sore point I have had with judging in the past. Twice I lost points because I was told the by pass hose should not be painted. One of the judges said I had too much paint on my exhaust manifolds, but also told me my original 772 fan blade was made in 1972 so I just ignored his opinions. I worked on these cars when they were fairly new and worked on many original corvettes and distinctly remember the by pass hoses on CAST IRON manifold cars were fully painted. The paint did not adhere to the rubber hose so after 40 years only the clamps and part of the hose has paint remaining on it. Aluminum intakes had a mask that also covered part of the by pass hose but that's a different animal. Last night I got view an Original owner 1966 427 Vette that is one of the most untouched cars I have seen in many years. Her car shows paint on both ends of the hose.This is a NCRS awarded car. The B&W photo is from Chevrolet archives and clearly shows the hose painted. Another archive from VN shows the how BB exhaust manifolds were painted. I will also post how I painted my engine and would like to get comments, positive or not, if you feel that I did it correctly. This engine has not run in 18 years so more paint will probably flake off after I start it.
Thanks for your time. George.
NoYenko
Re: Engine painting poll
« Reply #1 on: August 12, 2012, 05:57:58 PM »
Archive photos
NoYenko
« Reply #2 on: August 12, 2012, 06:02:04 PM »
Pictures off chevelle site, 2nd picture is LS6, 3rd picture is mine
NoYenko
« Reply #3 on: August 12, 2012, 06:04:33 PM »
Complete engine
« Reply #4 on: August 12, 2012, 07:29:18 PM »
 It's hard to argue a point that is very subjective with someone who may not be entirely educated in the process back then. Looking back at that time it was dependant on the person applying the paint to how far they wanted to go with coverage. Besides the bypass hose that was on the block when painted, the exhaust manifolds and bell housings (manual cars) and distributor clamp coverage were entirely up to the painter.
  I have my entire bypass hose painted and never got docked points when I showed my car many years ago. I had a discussion with a person just last week about the Camaro build process and I told him the early Camaros' front end sheet metal was painted by Chevy and the main body by Fisher. He still doesn't believe me that was how it was done  :(
Seeing the archice picture I may print that out just in case I encounter that situation like yours.
« Reply #5 on: August 13, 2012, 05:52:11 PM »
Your photos look fine to me. Iron-intake big-blocks didn't get any masking, and the bypass hose was pretty much completely painted; aluminum-intake big-blocks did get a mask, and their bypass hoses will show somewhat less paint than on an iron-intake car. Tonawanda painted the big-block engine with the exhaust manifolds in place, and they had lots of paint, as shown by the photo on the Camaro assembly line. Flint V-8 (small-blocks), on the other hand, installed the exhaust manifolds AFTER engine painting starting in 1965, so post-'64 Flint-built small-block exhaust manifolds won't show any paint.
Have your buddy read my "1st Generation Camaro Assembly Process" report if he doesn't believe how the body and sheet metal were painted; the Fisher Body/Car Division assembly plants painted the body and front sheet metal in different plants for 50 years.  :)
http://www.camaros.org/assemblyprocess.shtml
mickeystoys69RSSS
« Reply #6 on: August 13, 2012, 06:28:08 PM »
Interesting I though all of the manifolds were cast iron color. I will have to remember that if I ever paint mine.
NoYenko
« Reply #7 on: August 13, 2012, 10:22:36 PM »
Guys, thanks for the input. John I really appreciate your comments, that means allot coming from someone who oversaw or implemented operations like these at the plant. We are lucky to have you on board. George.
mickeystoys69RSSS
« Reply #8 on: August 13, 2012, 11:58:45 PM »
What is interesting is that in Jerry's book appendix E component color and plating chart shows the exhause manifolds as natural cast iron finish. Is painting them strictly for big block applications? I have had several 67-72 chevy trucks and always coated the exhaust mainfolds the cast iron gray color. This is the first time I have seen them painted orange.
« Reply #9 on: August 14, 2012, 02:31:28 PM »
Small-block exhaust manifolds were natural unpainted cast iron. Big-block exhaust manifolds were painted on the engine, but most of it burned off in the first hour of operation (the resulting smoke was a problem, so Tonawanda changed their process at some point in the 70's and installed the big-block exhaust manifolds AFTER engine painting).
mickeystoys69RSSS
« Reply #10 on: August 14, 2012, 03:50:46 PM »
So them would painting the manifolds with a Vht orange or ceramic powder coat so the color does not burn off be considered correct? I think I will just leave mine alone oxidized for now.
« Reply #11 on: August 14, 2012, 09:35:12 PM »
This is a photo of an L48 engine in a '69 Nova SS, taken at the dealership in 1969. Must have been a Tonawanda engine as they painted with manifolds attached. Tonawanda did not build 302s.
NoYenko
« Reply #12 on: August 15, 2012, 12:07:35 PM »
William nice picture. I think I have some old french locks off a small block manifold that have orange paint on them. Mickey I had my manifolds ceramic coated in a dark cast iron color then painted them orange. I  hope that as the paint burns off it will show dark iron color instead of rust. The picture below is from a 27 mile LS6 and you can see how quickly the paint burned off. Credit for taking the photo goes to (704EVER2008's). George.
mickeystoys69RSSS
« Reply #13 on: August 15, 2012, 05:49:52 PM »
George that is a good idea with the coating and paint. It will be interesting to see how well it will last.
« Reply #14 on: August 16, 2012, 12:56:52 AM »
Also notice the engine lift brackets being natural and not painted chevy orange.
Nice pic George to display.......
