Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
General Discussion
Convertible x codes
« previous
next »
Print
Pages: [
1
Author
Topic: Convertible x codes (Read 7468 times)
sixt9x33rs
Hero Member
Convertible x codes
on:
August 11, 2012, 01:33:51 PM »
Do all big block convertibles built within the "x code range" have either x-22 or x-66 on the trim tag notwithstanding pace cars?
FYI... My 04d (with 04L on the trim tag) has no x code on the trim tag but it is a small block non style trim car.
Looked at a 04c small block convertible this week with x11 on the trim tag in keeping with the style trim installed on the car.
Lawrence
Tweet
Logged
69pace
Hero Member
Re: Convertible x codes
Reply #1 on:
August 11, 2012, 03:12:46 PM »
GMAD Los Angeles plant assembled vehicles had no X codes on the tag. Norwood had them on the tags after December 12B build dates, and noted that"A few mid-year 69's, mostly convertibles, did not have X-codes stamped on the cowl tag. It is unknown why the code was not stamped on the tag."
http://www.camaros.org/numbers.shtml#XnnCodes
Logged
TeamCamaro - Moderator
CRG Member
Reply #2 on:
August 11, 2012, 04:02:45 PM »
For some reason it is not at all unusual for a Norwood convert to be missing the X code. Starts early spring and runs to the end of production. No discernable pattern; some just do not have it.
However none of the several dozen examples in the db were submitted as SS cars with 396 engines.
The alpha-numeric scheduling code Van Nuys used did include X but had no bearing on build configuration.
Logged
sixt9x33rs
Hero Member
Reply #3 on:
August 12, 2012, 01:08:34 AM »
I should have mentioned excluding LA cars. I know they don't have x codes. I am just trying to figure out if SS 350 or SS 396's had x codes anytime during the year.
So William you don't have any SS Convertible cars in the DB with x codes?
Logged
RAfbody
Member
Reply #4 on:
August 12, 2012, 02:06:49 AM »
I believe what he is saying is that non of the "non x code" convertibles in the database were submitted as an ss car with a 396 engine.
Logged
Russ
CRG Member
Reply #5 on:
August 12, 2012, 02:20:15 AM »
The db isn't big enough to draw conclusions. We have several X22, X55, X66 converts. None of the blank tag cars are 396 SS cars. One may be an L48 SS.
Logged
sixt9x33rs
Hero Member
Reply #6 on:
August 12, 2012, 11:41:05 AM »
Thanks William, that is what I was looking for. I appreciate it.
Lawrence
Logged
69glacierblue
Member
Reply #7 on:
August 19, 2012, 03:24:29 AM »
Don't know if this helps but my 06A vert is stamped X55.
Dennis
Logged
Dennis
'69 SS350 Vert (X55) 4-sp.
'10 2SSRS RJT M6
69houdini
Member
69 SS X55 Butternut Vert / 68 Z28 Rally Green
Reply #8 on:
August 21, 2012, 04:13:15 AM »
So is mine Dennis, 06A L48 Vert stamped X55 Butternut Yellow 40, Black Top
Logged
GI JOE
Member
Reply #9 on:
September 05, 2012, 05:54:23 AM »
Starting the second week of Dec 1968 (12B) the X code was used. All 396 SS cars from Norwood plant had an X code X22 or X66 starting on that date. Convertible Camaros after that date without the X code were low horse cars ie 307, etc.. However, it is possible to have an exception... Please read this
http://www.camaros.org/numbers.shtml#POPCodes
Logged
SFC GI JOE - Airborne Paratrooper
68- L-78, M22, BV
69- L-78, M22, BV, Conv
Print
Pages: [
1
« previous
next »
General Discussion
Convertible x codes
