Author Topic: Voltage Regulator Date vs Car Build Date  (Read 20702 times)
« on: August 08, 2012, 04:40:02 AM »
I have access to 2 voltage regulators for my restoration, both 1119515, one is 9A and the other 9C. Not sure which (maybe neither?) is the original, and therefore wondering which date would be more appropriate for an 04A VN car? Since the VR production dates cover the entire month, I'm curious to know if they were produced continuously throughout each month, or only in limited batches/runs - in which case it may not be likely that the 9C-dated part would have got to Van Nuys in time. I'm thinking the 9A is probably the more likely date for this part?
Re: Voltage Regulator Date vs Car Build Date
« Reply #1 on: August 08, 2012, 02:12:36 PM »
Go with the 9C. VR's were built everyday (literally hundreds a day), so either 9C or 9D would work in your case.
« Reply #2 on: August 08, 2012, 05:10:14 PM »
My 67's have the original VR's still and the dates are very close to the tag's build date.....
LOS 4B - VR=7C
NOR 5B - VR=7E
jdv69z
  • 69 RS Z/28 52E
« Reply #3 on: August 08, 2012, 08:01:59 PM »
Never checked mine. Where's the date?
Jimmy V.
Jimmy V.
« Reply #4 on: August 08, 2012, 08:18:00 PM »
Quote
Pictures of the date location is in THIS thread.
tmodel66
« Reply #5 on: August 08, 2012, 08:31:35 PM »
Quote
Ed I looked at the pictures in the other thread. What's the significance of the pencil mark Kurt pointed out?
« Reply #6 on: August 08, 2012, 08:38:16 PM »
QA check marks. Not seen on all VM's but if you look really hard, you might still see them on yours.
« Reply #7 on: August 08, 2012, 08:55:24 PM »
I've never checked mine either; but I just did and it's stamped 8A on a LOS 02C build.
« Reply #8 on: August 08, 2012, 09:13:32 PM »
Thanks everyone for your replies - will go with 9C on the car and 9A as a spare.
tmodel66
« Reply #9 on: August 09, 2012, 12:13:35 AM »
Thank you sir for the explanation.
jdv69z
  • 69 RS Z/28 52E
« Reply #10 on: August 09, 2012, 08:17:47 PM »
[/quote]
Thanks!!
Jimmy V.
jdv69z
  • 69 RS Z/28 52E
« Reply #11 on: August 15, 2012, 03:01:29 PM »
Checked my reg and it's stamped 8F. June '68, correct? Oct '68 build on car. End of '68 production used in early '69 production? It is part no. 1119515.
Jimmy V.
Jimmy V.
« Reply #12 on: August 15, 2012, 03:43:12 PM »
Quote
Wow. That's 4 months. Highly unusual.
jdv69z
  • 69 RS Z/28 52E
« Reply #13 on: August 15, 2012, 08:06:12 PM »
Maybe it's not original? Pic attached. Could it be 1979? I know it's not been replaced on my watch which started in 1982.
Jimmy V.
Jimmy V.
jdv69z
  • 69 RS Z/28 52E
« Reply #14 on: August 15, 2012, 08:07:36 PM »
Oops! I mean 1978.
Jimmy V.
Jimmy V.
