Author Topic: decode help - new to Camaro Z11 1969 pace car with 396  (Read 15761 times)
cstanley-gs
« on: August 06, 2012, 06:03:22 PM »
A friend just bought a 69 Z11 pace car. Convertible.
Z11 on cowl tag
has the right style body number
It has the 12 bolt rear
Has exhaust hanger on the frame for dual exhaust
Has the SS and 396 badges
Has the right paint and interior ... White 50 and hounds tooth 720 codes for a z11 Norwood car
4 speed
I'm a Buick GS guy so my Chevy motor identification skills are limited in determining a 350 or 396 and if it's numbers matching
The only number I can find in front of the passenger head is 11206JB
I found JB means 396ci/325HP L35
But not sure where the VIN should be to see if its matching
I appreciate any help
cstanley-gs
Re: decode help - new to Camaro Z11 1969 pace car with 396
« Reply #1 on: August 06, 2012, 06:14:45 PM »
Here's a few pix
Aftermarket Carb, got to see if the owner has the original
« Reply #2 on: August 06, 2012, 06:17:17 PM »
Welcome!  For the 1969 model year, the partial VIN for V8 engines was stamped in either of two locations: on the engine pad or near the oil filter.  The following link explains the details...
http://www.camaros.org/drivetrain.shtml#partialVINs
cstanley-gs
« Reply #3 on: August 06, 2012, 06:25:27 PM »
Thanks Paul!
The VIN was not on the top of the block so when we get this car back home I'll check by the Oil filter
 (from the link above)
« Reply #4 on: August 06, 2012, 07:07:54 PM »
11206JB is probably T1206J, which is a L35 (396/325) with a manual transmission assembled on December 6th, 1968 at the Tonawanda, NY engine plant. What's the build date on the trim tag (and the VIN)?
cstanley-gs
« Reply #5 on: August 06, 2012, 07:12:42 PM »
Thanks Ed
Build date is 02D
4th week of Feb, which was the first week of production for the Z11 cars.
cstanley-gs
« Reply #6 on: August 06, 2012, 07:40:10 PM »
Hope to have the car home this weekend, and will report back
« Reply #7 on: August 06, 2012, 07:48:35 PM »
Curtis, what's the VIN? That suffix date (December 6th) is a little too early for a 02D car, so it's probably not the original, but without knowing the VIN (and verifying it on the block), we can't be sure.
cstanley-gs
« Reply #8 on: August 06, 2012, 09:17:25 PM »
I have the VIN
124679N612251
« Reply #9 on: August 06, 2012, 10:07:29 PM »
124679N612251 lines up nicely with 02D, but I don't think that engine (or at least that block) is original to that car. We have a couple of other L35's in the database during that same time period and they're dated much closer to the build date of the car than that. Check for the VIN anyway. You never know!
srode
« Reply #10 on: August 06, 2012, 10:41:58 PM »
your VIN is a couple hundred before my 02D.  Cowl tag number from NOR is more than that, significantly, but they weren't in order.
cstanley-gs
« Reply #11 on: August 14, 2012, 11:40:00 AM »
I posted this over at Camaros.net, but will post here for people not on both threads...
I think we have a match
Car VIN ends in 612251
I can make out the 9N6
and the 251 last 3 digits, the rest is faint.  But looks like a match.
Hope to have the car on a lift in a couple weeks to check it further and find the trans stamping
cstanley-gs
« Reply #12 on: September 04, 2012, 03:05:33 AM »
In case you're wondering... It lives!!!!
Details are here - http://www.camaros.net/forums/showthread.php?t=211668
MyRed67
  • SZZLN 67
« Reply #13 on: September 04, 2012, 04:59:55 AM »
That is an L35/396, just has aftermarket Valve Covers and Carb.   Also an added bonus it looks like most of the Smog equipment is intact.
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
« Reply #14 on: October 01, 2012, 03:09:19 AM »
Nice score...
