Author Topic: 4 piston calipers on a 69??  (Read 6426 times)
DT
« on: August 05, 2012, 10:47:15 PM »
Was a 4 piston caliper ever an option on a 69 SS ??  Thx.
Donny
Re: 4 piston calipers on a 69??
« Reply #1 on: August 05, 2012, 10:58:15 PM »
Only with the JL8 option.
« Last Edit: August 05, 2012, 11:39:24 PM by 1968RSZ28 »
BlackoutSteve
« Reply #2 on: August 05, 2012, 11:01:20 PM »
Yes. JL8, which used a larger front (J56 Corvette) caliper than the smaller J52 67-68 calipers.
DT
« Reply #3 on: August 06, 2012, 08:34:10 PM »
Thanks guys. The J52 caliper was from a 67=68 Z28??
Donny
« Reply #4 on: August 06, 2012, 08:43:22 PM »
J52 was the disc brake option for 67 and 68. Required on the Z28, but optional on all the others.
« Reply #5 on: August 06, 2012, 09:17:39 PM »
JL8 Camaros used modified standard 4-piston Corvette calipers and 11-3/4" rotors on all 4 wheels, not the heavy-duty dual-pin J56 calipers. J56 is very rare in the Corvette world.
For '67 there was a J56 "heavy-duty brake" option for Z/28. It used the standard Camaro caliper but used different pistons with insulators and metallic rear brake shoes.
J52 is the order code for power disc brakes, a required option on Z/28 for '68-'69 and standard on '69 SS. For '67 only J52 didn't include power brakes; manual front disc brake cars were built but no Z/28s are known. J50 "vacuum power brake" also had to be ordered. '67-'68 front calipers were 4 piston but not the same as Corvette. For '69 the design was changed to single-piston.
« Last Edit: August 06, 2012, 09:38:35 PM by william »
BlackoutSteve
« Reply #6 on: August 07, 2012, 06:53:07 AM »
Ahh, thanks for that. Interesting.
Then I assume that there is no RPO code for the standard Corvette disc brakes. ..because those were standard on all models?
Do you know what the mods made to the standard Corvette calipers were for the JL8 option on Camaros?
« Reply #7 on: August 07, 2012, 12:55:18 PM »
The best source for JL8 info is Wayne Guinn's book "Camaro Untold Secrets 1967-1969." The JL8 chapter is over 30 pages.
The standard equipment '65-up Corvette caliper used a single pin to retain the pads.
To the best of my knowledge the caliper inner halves as used on JL8 were machined differently to relocate the bleeder. I believe they had an X cast into them for ID. Some racers modified the JL8 system to use dual-pin HD Corvette J56 calipers.
