Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Originality
69 z28 carb.insulater
« previous
next »
Print
Pages: [
1
Author
Topic: 69 z28 carb.insulater (Read 7102 times)
canadair
Member
on:
August 02, 2012, 10:18:49 AM »
Did the holley carb use a heat insulater between the carb and manifold on the 302 engine.
Tweet
Logged
CRG Member
Re: 69 z28 carb.insulater
Reply #1 on:
August 02, 2012, 01:04:35 PM »
Depends on how "heat insulator" is defined.
Holley carbs used a gasket between the carb and manifold as shown in the assembly manual. They did not use a metal plate as some Quadrajets did.
Logged
canadair
Member
Reply #2 on:
August 02, 2012, 03:57:09 PM »
this insulater was a gasket and metal shield seperating heat from the intake maifold from the split gas lines.
Logged
Hero Member
Reply #3 on:
August 02, 2012, 04:11:48 PM »
If you mean
THIS
(P/N 3969835 for the Holley and 3969837 for the Q-Jet), it wasn't used in 1969. They started using these in 1970.
Logged
CRG Member
Reply #4 on:
August 02, 2012, 04:50:23 PM »
I do not believe that was ever used in production.
Logged
CRG Member
Reply #5 on:
August 02, 2012, 04:58:16 PM »
I remember an insulator/shield llike that being installed on an IROC Z/28 I had at the dealer as part of a TSB on fuel percolation/rough idle.
Logged
Hero Member
owner since 4-Apr-1976
Reply #6 on:
August 03, 2012, 05:21:07 AM »
they do have a GM part number, and I recall seeing them around that time frame, but not on '69's..
Gary
Logged
72 El Camino, '55-'56-'57 Nomads, '55-'57 B/A Sedan
CRG Member
Reply #7 on:
August 03, 2012, 02:06:02 PM »
Holley carbs were phased out of production after '71; maybe the few '72 Z/28s built still used them. There are plenty of vintage magazine photos of those cars and none of them used it.
Logged
Print
Pages: [
1
« previous
next »
Originality
