Author Topic: 68 Original Wide Tread Tire & DF wheel, weights, and valve stem  (Read 8418 times)
Recently I had the good fortune to come across an original 68 Wide Tread Tire and DF wheel that
I feel is unmolested and totally original. Wanted to share and also learn from the valve stem as its
different from what I thought I knew about.  All I ever read about were Dill valve stems!
I believe the tire is dated Jan68? It came from the original owner of the 68Z/28. Micro weight is like new!
Plan on using this as our spare but leaving it the way it is. What do you think?
Oh, and I checked the valve stem length of several DF wheels along with other Corvette rally wheels (68)
and they all stick out approximately 1.300". Opps, wrong length!
Re: 68 Original Wide Tread Tire & DF wheel, weights, and valve stem
« Reply #2 on: July 21, 2012, 01:53:07 AM »
Thanks Paul! That valve stem cap with "Schrader" has me curious.
1968 Z28
« Reply #3 on: July 21, 2012, 02:47:30 AM »
Hi Chick...Is this a case of I'll show you mine when you show me yours? ::)
Here tis...this is an all original...been on ground but has not had rings applied...note cap on stem.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
1968 Z28
« Reply #4 on: July 21, 2012, 02:50:39 AM »
These last two are a better shot of the backside that has the assembly plant markings.  These markings also show on the front valence panel and the firewall.
Jerry G.
« Reply #5 on: July 21, 2012, 10:12:40 AM »
Great pics Jerry! Hard to find examples like this. Good on ya!
Also good to see the date of tire/wheel (both July) vs. your 07C.
« Reply #6 on: July 21, 2012, 11:38:28 PM »
What does the 22 represent? 22 week of the year?
1968 Z28
« Reply #7 on: July 22, 2012, 04:34:12 AM »
This link I am including can explain it better.....
     http://www.camaros.org/forum/index.php?topic=966.0
Jerry G.
