Author Topic: Brake & Gas Liine Clip 3881339  (Read 7551 times)
« on: July 20, 2012, 01:13:55 PM »
Believe all the 3881339 clips in kits have a type of reddish clay color clip but most restorations observed have that clip
painted black. What was the correct color?
Re: Brake & Gas Liine Clip 3881339
« Reply #1 on: July 21, 2012, 12:31:40 AM »
Went through our clips and found one that you could clearly see was phosphate.
Were there differences depending on where they were used, i.e. gas vs. brake?
« Reply #2 on: July 21, 2012, 01:34:08 AM »
 I'm in the same situation too with my current 67 NOR conv restoration and the clips I got from In-Line. I have the original ones I took off in the 80's and those that are in fair shape to display a finish show no red color. But that's not to say it hasn't faded but I would think the rear parts that are against the chassis would retain something.
My 67 LOS survivor that has original fuel and brake clips preserver in a layer of grime are clearly phosphated. I may take the repo ones and glass bead then phosphate
unless there are others here who can say they have seen colored ones.
rat pack
« Reply #3 on: July 21, 2012, 07:19:36 PM »
All of the ones I have are a grey/black phosphate......I put them on my car that way too.........RatPack...................
luv2sixty9
« Reply #4 on: May 14, 2019, 04:21:12 PM »
I also started researching this today for I'm getting original clips ready for my 67 and found that they are either phosphate or an olive green.  I found both finished and I'm wondering if one is for the fuel and one is for the brake even though they are the same clip. Any help would be appreciated. Thanxs Dave
1967 Z/28 Butternut Yellow
1969 Z/28 Rally Green
1969 RS Z/28 Lemans Blue
1969 RS Z/28 Olympic Gold
1969 RS SS Pace Car
2010 Aqua Blue 2SS RS
« Reply #5 on: May 18, 2019, 09:39:20 PM »
Dave, Skips 68 did not show any color and what I’ve seen indicates  at least early (67&68) Camaro’s had phosphate clips.
