Author Topic: Looking for another decal project to consider  (Read 20086 times)
Don_Lightfoot
« on: July 09, 2012, 11:02:52 PM »
We would like to take a look at another decal project where the repro is not accurate or one that is not being made at present.
I have had some requests for the 68 Z/28 Emission Decal, but do not have a high resolution, quality picture to work with.  If anybody could provide such a picture we could take a look at doing it.
I have also had requests for the 69 Camaro Jacking Instructions Decal.  I have no idea how many different ones were made for that year, but I would assume several.  We may consider looking at the most popular one (EG - most widely used) if somebody can provide a picture.
Thanks.
WEBSITE
Specialized Chevrolet Decals
mickeystoys69RSSS
Re: Looking for another decal project to consider
« Reply #1 on: July 10, 2012, 12:35:27 AM »
I do not have one but how about a correct tire pressure decal for a 69?
« Reply #2 on: July 10, 2012, 05:25:56 AM »
I second that, how about a correct tire decal for the 69 Z
Don_Lightfoot
« Reply #3 on: July 10, 2012, 01:20:17 PM »
We have done three Tire Pressure decals for 69 Chevelles - BC, DC & DL.  I wouldn't think any of those would be the same for the Camaro.
We could consider looking at the more popular ones - Z/28 & SS for example - if somebody can provide quality pictures of originals.
WEBSITE
copo
« Reply #4 on: July 10, 2012, 06:15:21 PM »
How about doing the 69 396 /375 hp Emission Decal.
« Reply #5 on: July 10, 2012, 06:20:43 PM »
OR the 'late year'  '69 small block emissions decal??   As I understand it, the one you just finished was replaced later in the year, thus is not appropriate for my September Z28?
« Reply #6 on: July 10, 2012, 06:58:30 PM »
What is the difference? when did they switch?
Don_Lightfoot
« Reply #7 on: July 10, 2012, 08:56:13 PM »
That one is done, go to my website for the information.
WEBSITE
« Reply #8 on: July 10, 2012, 10:24:12 PM »
Don, I have not checked but maybe some wise members here will know about the coil are rear spring tags being correct or not. Thought I have read that the repros are not correct but not 100% sure or do I have anything to compare to. Know Don you re-did those for Chevelles if I remember correctly and those are used by a lot of people and would think they would be easy compared to other decals.
Everyone, how are the repro coil spring and leaf spring decals to originals?
Thanks Don! Received the decals ordered yesterday......
« Reply #9 on: July 11, 2012, 06:46:06 PM »
I've forgotten Don, do you have the correct 68 Z28 Emission decal?
Don_Lightfoot
« Reply #10 on: July 11, 2012, 08:53:44 PM »
No I don't Chick.  That is one we would consider looking at as mentioned to start this thread.  Do you know if the code for that one is "P"?  If so, I have two pictures on file, but they are nowhere near good enough for us to work with.
WEBSITE
rat pack
« Reply #11 on: July 11, 2012, 10:43:24 PM »
I haven't seen anyone doing 100% correct leaf or coil spring decals for the first gen Camaro. The ones out there today are printed on a vinyl/plastic type of material and are way to glossy. Most are not even the correct colors, especially the 69 mulit leaf "BM" code stickers. The originals are a cloth/paper type material in silver and have black lettering; the repros are yellow with black lettering and there is one that doesn't even have the correct font! Don I would love to see someone make these decals correctly. I may be able to supply with originals to make repros for certain applications......................RatPack............................
Don_Lightfoot
« Reply #12 on: July 12, 2012, 03:09:52 AM »
rat pack - Spring tags is the exact reason I got into this "dacal" stuff about 9 or 10 years ago.  When I was searching for spring tags for my F41 69 Chevelle there were none available.  The suppliers, and producers of them, only had tags available for the more common cars.  A GM bulletin I have indicates a total of 9 different front springs and 7 different rear springs available for 69 Chevelles.  Seems to me I saw something regarding 69 Camaros and they had even more.
Anyway, I made up my own spring tags for my 69 Velle.  The word started to get around and I ended up doing lots of them for fellow Chevelle enthusiasts.  Most of them were similar to my situation wherein the codes they needed were just not available elsewhere.  Then the Camaro guys started asking for them and I have done numerous of those as well.
Keep in mind my research was done for Chevelles.  Any Camaro input has come from the owners themselves as far as codes, numbers, colours, etc.  Mine are obviously not in the form you refer to as far as "texture" of the product.  Mine are done on peel off backing paper and are sealed on the surface with clear 3M vinyl.  Somewhat glossy yes, but maybe not as much as what you are referring to.  Also, the fonts were taken from original Chevelle tags way back when.  I use the same fonts for the Camaro tags which may, or may not, be correct based on some of your input.
Here is a picture from my website of the first Camaro springs I did years ago.  My templates are such that any colour of print and background are available. Just thought I would give a little history on the ones I do.
WEBSITE
rat pack
« Reply #13 on: July 12, 2012, 12:29:56 PM »
Don, we need to talk! Check your private messages...............RatPack.................
« Reply #14 on: July 12, 2012, 11:29:57 PM »
ratpack, that is what I have read, i.e. repro's not correct. Thank You! Maybe Don can help us out.......eh!
This one is advertised as correct but is it other than the material being incorrect as you mentioned (color/font acceptable) or?
http://www.heartbeatcitycamaro.com/store/product/17125/Camaro-Coil-spring-decals-EE-3932771-68/
And what about this repro for the rear springs? Supposed to be correct other than material used or?
http://www.heartbeatcitycamaro.com/store/product/17134/Camaro-Leaf-spring-decals-OA-3930080-68/
These are examples of what I have but have not used to this point.
