Author Topic: 67 mono springs use decals?  (Read 18525 times)
KevinK
    • Hudson Valley Camaro
Re: 67 mono springs use decals?
« Reply #15 on: August 18, 2012, 01:36:13 PM »
 Just chiming in (since I found this through the search)
   I'm trying to find what would be correct tag for my '67 (LOS 11B built) convertible, ...and now wondering if it only got the/a paint stripe on the leaf...? (if so, ...what color)
   I will also check my '67 coupe survivor (41K miles) another early LOS build (327/275) to see if I can find a stripe, ...and will add to this thread...
  Kevin
« Reply #16 on: August 18, 2012, 05:07:28 PM »
Kevin, what engine do you have in the convertible?
KevinK
« Reply #17 on: August 19, 2012, 12:39:11 PM »
  ...sb 350, ...but also factory A/C which I suspect will determine correct spring.
  (for the record, my survivor 67 coupe is a 327/275hp with A/C)
   Kevin
« Reply #18 on: August 19, 2012, 05:06:33 PM »
Kevin, the rear springs for your car would be either 3909941 (BJ code or a dark blue stripe), or 3920220 (BA code or no stripe) if you have RPO G31 (Heavy Duty rear springs).
x77-69z28
« Reply #19 on: August 20, 2012, 08:47:44 PM »
my 12D 67 rs/ss had a coral paint stripe
« Reply #20 on: August 20, 2012, 08:58:15 PM »
Quote
You must have a Coupe. Springs are different between Coupes and Convertibles.
67 rss
« Reply #21 on: August 21, 2012, 04:49:26 AM »
If your looking for data...my 67 LOS 3D SB Coupe had tags..the upper half mostly intact..the lowers missing with a remaining groove from the undercoating "overspray" which remains on the springs today...ugh..
Lane
x77-69z28
« Reply #22 on: August 22, 2012, 01:03:39 AM »
yes ed, it is a coupe.
