Author Topic: Starter Date Code for September 69 Build  (Read 8880 times)
Mac B
« on: July 01, 2012, 11:34:18 AM »
What is an acceptable date code for an SS-396, 325 hp built in September of 1969?  Thanks for your help.
IZRSSS
  • Guest
Re: Starter Date Code for September 69 Build
« Reply #1 on: July 01, 2012, 02:46:00 PM »
My 69 L48's build date is 12A (Dec. 68 - 1st wk). My starter date is 8L4 (68-Nov-4Th). Personally, I’d look for something from 1 month to within 2wks prior to your cars build date. If not, up to 3 months prior is acceptable.
vtfb68
« Reply #2 on: July 01, 2012, 06:20:52 PM »
Mac,
 The starter was part of the motor assembly and should be dated before the MOTOR was built.
The less common motors tend to streach further from the CAR build date. I understand those engine parts were built in lots, I also need a lot/Build date for a #365 starter for a 3 26 68 built 396. Sorry, I do not know the date you need either.
   Victor
68 08E LA RS Y2 749 L30 M35
« Reply #3 on: July 01, 2012, 06:41:43 PM »
Mac,
   Victor
Nope. The starter was installed at the car assembly plant, not at the engine plant; it should be dated relative to the car's final assembly date.
vtfb68
« Reply #4 on: July 01, 2012, 09:27:04 PM »
John,
 What engine pieces were assembled with the engine? Distributor, Alt, Carb, Manifolds? Any Idea on lot  dates?
    VT
Mac B
« Reply #5 on: July 01, 2012, 10:48:21 PM »
Thanks for the help on the date.  Now all I have to do is find one.  Mine is dated after the car was assembled. If anyone has one with  a July or August 69 date I am interested in purchasing it.
Mac B
« Reply #6 on: July 01, 2012, 10:57:22 PM »
I have found one with the following code:  1108418 9F17.  Is this acceptable for a September 1969 built car with a 325 hp 396?
IZRSSS
  • Guest
« Reply #7 on: July 02, 2012, 01:43:25 AM »
What is your cars build date; JA, JB, JC or JD?
The reason I'm asking is because you are cutting it real close to that 3 month spread.
« Reply #8 on: July 02, 2012, 02:14:50 PM »
John,
    VT
See the "Chevrolet Assembly, Engine Dress Line Operations" section in my CRG Report below for a description of the components added to the engine at Norwood and Van Nuys:
http://www.camaros.org/assemblyprocess.shtml
Mac B
« Reply #9 on: July 17, 2012, 11:33:37 AM »
Checked the code with Jerry and he says it is OK.
