Author Topic: Red Oxide primer on interior or 68 Camaros- Jonn Z and Ed Please respond.  (Read 21676 times)
Here's a pic that Jon took of a 68 NOR, built mid-March.
Mine looks like that last picture Kurt put up.
rat pack
The pattern so far is this: 68 Norwood cars only, exterior/interior colors did not change this base brown primer color. I have yet to observe any LOS cars, or any 67 NOR cars with anything other than grey.  Would like to see if this shows up in 67 Norwood cars at any time frame. I have pictures of Norwood cars from Jan 67 thru the end of production in July and all have grey primer inside and out. So if you have a Norwood 67, or any LOS 67-68 with this brown primer I would like to hear from you along with pictures to verify it..............Thanks.......RatPack......................
vtfb68
rat pack,
 Pictures were sent to your E-mail.
  VT
68 08E LA RS Y2 749 L30 M35
Mine's LOS, but I don't think I have any pictures as all I did was change carpets out.  I'll look under the sills for anything.  Other than that it might be a while.
noschevys
Hi, I will post pics of my norwood 07c 68.  Keith
noschevys
Here are some pics
rat pack
rat pack,
  VT
Victor...check to make sure those pictures went through as I don't have any....
Probably won't find it under the sills, but pulling the rear seat bottom out would probably work...........also look up under the dash over behind the kick panel area........ Have yet to see a LOS car with this color in 67 or 68................RatPack................
vtfb68
ratpack,
 I re-sent the 68 pictures to your E-mail.
  Victor
I know pics are pics without seeing in person but looking at Keith's primer to some 69 similar primers (pics I took) I'm not seeing the red vs. brown primer differences as they look about the same. What I'm thinking is maybe the 69's I have looked at including ours is the same primer used on 68's like Keith's.
69 survivor pic
TJM68SSRS
68 SS/RS 11D Nor Teal Blue. The interior and trunk of my 68 was covered heavy with brown primer. The heaviest was the back side of the dash. The rest of the interior looked like a combo of all the above photos.
