Author Topic: muncie/saginaw 3spd date stamp and casting numbers help  (Read 5703 times)
zwigandt
« on: June 19, 2012, 08:28:02 PM »
its looks like muncie or saginaw,  i know its a 3 speed. main casing # 3852882   gm1 the other main casing # gm8 395265  and the number 8 or 6 not sure the serial tag on one the side plate bolt 3968081 and the date stamp is M1k31A this number is clear as day was under a ton grease. I cant find nothing on this trans.this transmission has my curiosity peaked it would be nice to know what this transmission is. thanks for any help
zwigandt
Re: muncie/saginaw 3spd date stamp and casting numbers help
« Reply #1 on: June 19, 2012, 08:33:12 PM »
oh,,, the main casing is 11" to 11"1/4 inches long from where the bell housing bolts on to where the tail shaft bolts on
« Reply #2 on: June 19, 2012, 09:21:14 PM »
3952656 is a Saginaw 3 speed used on the following cars:
zwigandt
« Reply #3 on: June 19, 2012, 09:53:01 PM »
so its worthless scrap metal...
zwigandt
« Reply #4 on: June 19, 2012, 09:53:53 PM »
thanks
