Howdy Troops,
I need 2 correct upper fender bolts that have captured washers and are at least 1 1/4 to 1 3/8 in diameter, the larger size washer the better. The heads can be 9/16th or 3/8ths. The lower bolts are the originals but switching them out does not solve the problem, just reverses it.
When the car was factory painted the original bolt/washers were large and left a paint halo. When we repainted the car some how the original uppers disappeared probably when refinished and not returned to us so smaller diameter washer ones were used, the halos sticks out like a sore thumb. I want to cover the halo with larger diameter but correct bolts with thin washers. I have tried AMK, Heartbeat city and every other place I can think of to try to find correct head stamped captured larger diameter washer bolts but no luck...............any suggestions or if you have some old bolts available I would truly appreciate it. The washers are thin not thick ones and the bolts are spear tipped not flat end. Bolt part # is 3963329 and clearly shown in the AIM. You can PM me off board to discuss if you like. Appreciate any help you can lend and thanks for taking a few minutes to help us out.
Best Regards from the sunny beach in So Cal.
Michael Kellogg
LM69Z28
