Author Topic: valve cover torque setting  (Read 18096 times)
dab67
  • 67 SS
« on: July 11, 2006, 09:52:53 AM »
Can anyone tell me if there is a correct torque setting for the tighting down of valve covers for a 350V8?
Thanks  dab67
Re: valve cover torque setting
« Reply #1 on: July 11, 2006, 03:42:46 PM »
It's 45-50 INCH-pounds; don't over-tighten - it'll distort the cover and cause a leak.
rich69rs
  • LF7/M35/Z22/Z87
« Reply #2 on: July 11, 2006, 04:23:14 PM »
45-50 in-lb is essentially 4 ft-lb; reasonably snug and as previously stated, don't overtighten.
If you are going to use a 1/4" drive torque wrench, I'd suggest "testing" on a similar bolt off of the engine so you can get the feel of the torque wrench.  I've seen some 1/4" drive torque wrenches where it is pretty difficult to "feel" the indent or click when the torque setting is reached.  Tendency is to keep pulling.
If you don't use a torque wrench, I would suggest tightening with a 1/4" ratchet  by turning the ratchet head with your finger tips and not the handle - snug 'em up and you'll be in the ballpark
« Last Edit: July 11, 2006, 04:38:52 PM by rich69rs »
Richard Thomas
1969 RS
dab67
  • 67 SS
« Reply #3 on: July 11, 2006, 07:08:30 PM »
Thanks John and Rich, I will tighten them using a 1/4 ratchet using my fingers. I'll let ya know the outcome.
Dave
dab67
  • 67 SS
« Reply #4 on: July 12, 2006, 09:47:42 AM »
John and Rich:
I tighten the new covers down as specified. I ran the car for about 30 minutes to get everything nice and hot and then checked for any leaks. Did not find any.
Thanks again!
Dave
