Author Topic: Subframe  (Read 4498 times)
Rich F
Subframe
« on: May 26, 2012, 03:28:08 PM »
Does anyone know if the cross member and trans mount are offset on a 69 firebird subframe vs a 69 Camaro?
I have not been able to find information on the location of these, just the body mount and radiator mount locations.
I am currently in the process of restoring a 69 396 Camaro and the Engine seems to be to far forward.
The subframe is out of a 69 Firebird which i was told would work. All the mounting holes to mount the body / radiator were the same.
The motor mounts are in correctly with the taller mount on the drivers side.
The Z bar for the cluth is not straight and is angled towards the front of the car and the driveshaft is short about 1".
Help is greatly appreciated.
Thanks Rich
Paul68RS/Z28
Re: Subframe
« Reply #1 on: May 26, 2012, 10:28:01 PM »
Rich,
I can't remember the exact details, but I had a friend put their mounts onto the frame incorrectly, resulting in the motor sitting about an inch forward. I honestly can't remember how they did it, but I will tell you I was there to lift the engine, and put the mounts back into the correct locations/holes. The frame was out of a Firebird, not sure if that was part of the problem or not, just remember the whole thing was a real PITA. Can't speak to the cross shaft, car was an automatic.
I'll actually see that car in June, I'll take a look and see if I can see how they had made the mistake in the first place.
DT
Re: Subframe
« Reply #2 on: May 26, 2012, 10:46:52 PM »
A firebird crossmember looks identical (almost) to a Chevy BB 4 speed crossmember. They are different.  The subframe will work.
Donny
Rich F
Re: Subframe
« Reply #3 on: May 27, 2012, 01:52:19 PM »
Any idea on why the z-bar would be angled towards the front of the car on the engine?
