Author Topic: numbers on master and booster  (Read 7320 times)
RJ_RS_SS_350
« on: July 09, 2006, 02:50:37 PM »
Hi everyone, thanks for all the help so far.  I was wondering what numbers should be on the master cylinder and brake booster for my 67 01A LOS build with front disc brakes.  And do all 67 small block engines use the same booster, metering block, etc. with only the master cylinder changing as the application changes?  ??? thanks again,  Randy
