Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Decoding/Numbers
1111480 dist
« previous
next »
Print
Pages: [
1
Author
Topic: 1111480 dist (Read 4853 times)
ban617
Member
1111480 dist
on:
May 07, 2012, 01:22:35 AM »
Hi ,I just aquired this Dist but what I find is weird it has dual points no vac advance ...Dated 9 A 2 Has delco remmy dual point cap and rotor ? Any ideas? Thanks
Tweet
Logged
mickeystoys69RSSS
Member
Re: 1111480 dist
Reply #1 on:
May 07, 2012, 02:12:00 AM »
If is was taken apart at some time the vac advance could have been removed or changed. The plate that holds the vac advance diaphram just screws to the dist. housing under the mech advance cam plate. Very easy to do. See pic number 5 and 7 here:
http://www.camaros.org/pdf/timing101.pdf
Logged
Print
Pages: [
1
« previous
next »
Decoding/Numbers
1111480 dist
