Author Topic: 1969 Camaro - Could you order a clock on a column shift non-console car?  (Read 9025 times)
sdkar
Hey guys,
I have a question.  For a 69 Camaro with column shifter and no console, could you order a clock?  I am trying to decide if I should go with a Speedometer/Clock(center)/Fuel Gauge setup if it would be correct.  What about a Speedometer/Fuel Gauge (center)/Tachometer setup.  Which setup is correct?  Could you order a clock or a tach on a non-console car?
Yes, you could order a clock. In fact I have a cluster just like that.
I believe U16 tach became available right about the time your car was made.
Neither required a console.
sdkar
So, the Speedometer/clock/Fuel could be had.  What about Speedometer/Fuel (center)/Tachometer?  I would rather try and keep the tach but if it wasn't an option, I will stay with the other setup.
That's U16.
sdkar
Thanks for the info Kurt.  It looks like I can go either way with the gauge setup.  I really like the clock and it is handy, but the tach is cool too.  I suppose a Speedo/Clock/Tach setup wouldn't be practical.  I am sure when I get ready to install them, it will hit me as to which one I want to go with.
69houdini
  • 69 SS X55 Butternut Vert / 68 Z28 Rally Green
sdkar, speedo/clock/ tach yes impractical w/o fuel gauge
I'm on time, I should shift, I'm not going to get a ticket.
Oh, I'm out of gas......  Yeah, a fuel gauge is recommended.
Kelley W King
My 69 has speedo, center fuel guage, and tach with no console. If it had a clock and tach there is no where for the fuel guage without the console. Also note that this setup has only temp and oil lights.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
hgger69
  • Hugger orange rules!
    • Håkans Motorsida
I have the speedo/fuel center/tach in mine and is perfect! I have like a clock in the iPhone! ;)
...I always cut the battery power when parking so a clock is useless for me anyway...
Kurt, my X44 is an 02D, was that combo I have available then?
Hakan from Sweden
www.hakansmotorsida.com
No, U16 with the center fuel gauge didn't come out until late April.
But I won't tell anyone.....
hgger69
    • Håkans Motorsida
Ha, ha, thanx Kurt it´ll be our secret!!
Hakan from Sweden
