Author Topic: Did console gauge cars also have a low oil pressure switch?  (Read 46545 times)
Re: Did console gauge cars also have a low oil pressure switch?
« Reply #30 on: February 28, 2013, 01:23:05 AM »
Looks like we are starting to get a good sample size to see what the transition period was.
 Feel free to add to this if you have a 67 with original gauges.
Cowl   Car   Firewall
Date   Plant   Junction
_________________________
02C   LOS   Grommet
02E   NOR   Brass
03B   NOR   Brass
03C   NOR   Brass
05B   NOR   Grommet
05C   LOS   Grommet
05E   NOR   Brass
Buddy (X77-69z28), what month and plant is your 67 with the brass fitting?
mickeystoys69RSSS
« Reply #31 on: March 02, 2013, 06:51:35 PM »
mark the page post.
x77-69z28
« Reply #32 on: March 02, 2013, 11:17:42 PM »
Mike, my car is a 12D Norwood car. Brass fitting
« Reply #33 on: March 02, 2013, 11:29:39 PM »
 Updated with 12D
Cowl   Car   Firewall
Date   Plant   Junction
12D   NOR  Brass
02C   LOS   Grommet
02E   NOR   Brass
03B   NOR   Brass
03C   NOR   Brass
05B   NOR   Grommet
05C   LOS   Grommet
05E   NOR   Brass
mickeystoys69RSSS
« Reply #34 on: March 03, 2013, 09:29:13 PM »
Photo of the firewall for the oil pressure line to the console gauge. It has a grommet but you can see the score mark in the paint wher the brass fitting used to be. It must have been repaired at one time and changed to the grommet. 11C 1968 build.
1967RS/SS
« Reply #35 on: March 08, 2013, 10:39:49 PM »
Is any one able to tell me if the line and fittings need two of the small barrel sleeves (one on each end)?  My block fitting came with only one of these sleeves. If only one is needed what side does it go on (block or gauge)?
1967 RS/SS L-48
Van Nuys 01C
Joseph
