Author Topic: Z28 photos  (Read 27405 times)
427-KING
Re: Z28 photos
« Reply #30 on: May 03, 2012, 04:00:38 AM »
trans related
427-KING
Re: Z28 photos
« Reply #31 on: May 03, 2012, 04:06:49 AM »
pic
427-KING
Re: Z28 photos
« Reply #32 on: May 03, 2012, 04:13:23 AM »
pic
427-KING
Re: Z28 photos
« Reply #33 on: May 03, 2012, 04:13:58 AM »
1
427-KING
Re: Z28 photos
« Reply #34 on: May 03, 2012, 04:14:29 AM »
1
427-KING
Re: Z28 photos
« Reply #35 on: May 03, 2012, 04:15:12 AM »
1
427-KING
Re: Z28 photos
« Reply #36 on: May 03, 2012, 04:25:25 AM »
transmission mount is    #3935704  BLUE
Re: Z28 photos
« Reply #37 on: May 04, 2012, 01:12:08 AM »
Thanks for taking the time to post Chuck! Some great pics of what seems to be one great car. You gona keep it now?
JoeC
Re: Z28 photos
« Reply #38 on: May 04, 2012, 12:36:40 PM »
looks like some of the shifter parts may have been changed
 on the trans levers , it looks like someone used the Hurst type clip which ruins the original molded rubber bushing
The trans lever rubber bushing should look like the rubber on the shifter levers
Did it have washers and cotter pins on the shifter end of the rods?
the rubber on the shifter levers looks to be in very good shape
On the shifter mount plate the two hex bolts look correct but the 3rd bolt is normally a philps button head screw which is needed for clearance
On the side of the shifter , should be a number with a date code
the car looks to be in great shape
427-KING
Re: Z28 photos
« Reply #39 on: May 04, 2012, 02:19:40 PM »
shifter
rsr
Re: Z28 photos
« Reply #40 on: May 05, 2012, 01:33:14 PM »
I saw that car in person many years ago when Lynn had just bought it from the original owner and it's a very nice original Z.The guy had kept a ledger best I remember on miles and work done since new.Thanks for sharing the pics!!
pjbizjak
Re: Z28 photos
« Reply #41 on: May 08, 2012, 09:59:08 PM »
I noticed in one of your replies you said the dist was a 111480 dated 9A20 (Jan 20 1969) and the engine build date was v0922DZ (Sept 22 1968?), something doesn't sound right.
mickeystoys69RSSS
Re: Z28 photos
« Reply #42 on: May 09, 2012, 03:22:40 PM »
0922 is the engine assembly date. The block and or heads casting date would tell if it is a 68 or 69. Since the distributors were made in batches, I am not sure if a 8 month sepearation between the dist date and the engine assembly is unusual or not, but the rear is also a 09 15 assembly date which is correct.
427-KING
Re: Z28 photos
« Reply #43 on: May 10, 2012, 04:54:19 AM »
Build date is Sept 69 not 68. Also has a 6000/7000 tach, most info out there says the changeover to 6000/8000 took place much earlier. havent had a chance to look under the dash as of yet for the harness codes   None of the items were ever changed as per the original owner.   .
