Author Topic: ss 350 4spd options  (Read 27249 times)
mossyoak1964
Re: ss 350 4spd options
« Reply #15 on: April 15, 2012, 09:42:42 PM »
Kevin - So far everything checks out. The pad looks great, including the cowl. See if you can get me a straight on shot of your POP and I'll brake it down for you as well. A pic of the partial vin on the tran would be nice also.
The only thing that I have decoded differant is under the Option 2 L=M20/M21 4spd. This car currently doesnt have fold down back seat.
Kevin,
1967 L 48 SS 350 4spd
Marina Blue/White
mossyoak1964
« Reply #16 on: April 15, 2012, 09:49:55 PM »
Is there any way other than pulling the cover on the trans. to determine if this is a M20 or M21? Everything I see has not indicated that this is not a M21.
Kevin,
Marina Blue/White
IZRSSS
  • Guest
« Reply #17 on: April 15, 2012, 10:24:56 PM »
I haven’t had anything stronger than water the last couple days, really; hiccup, hiccup, hiccup. :-\
3x a charm ???
(1) W-Tinted (windshield only)
(2) L- 4 speed floor shift {“M20/M21”}
     G- Console front compartment
     S- Antenna manual-RR
     R- Speaker rear
(3) S- Interior décor grp
     D- Lamp courtesy (coupe-under dash only)
     K- Ext moldg grp
(4) P- Radius rod
(5) Y- Belts deluxe
IZRSSS
  • Guest
« Reply #18 on: April 15, 2012, 10:29:01 PM »
Follow the RPO on the left hand column until you see M21 and check the requirements (off to the right). There is no way a M21 would have come from the factory in a L48. If it did it would show up here; http://www.camaros.org/pdf/options.pdf
Do you have any numbers off the side of the trans? This should tell us exactly what you have. You can find the "Maincase Casting Numbers" here; http://www.camaros.org/trans.shtml#4speed
mossyoak1964
« Reply #19 on: April 15, 2012, 10:49:45 PM »
Marty,
I have sent you the trans, and POP. I had a hell of a time locating the partial Vin # on the trans. It was located on top back by the tail housing. Thanks again!!
Kevin,
Marina Blue/White
mossyoak1964
« Reply #20 on: April 15, 2012, 10:56:22 PM »
Here is the #'s on the case: 3885010  3088336  3857584 tail housing.
Kevin,
Marina Blue/White
IZRSSS
  • Guest
« Reply #21 on: April 15, 2012, 11:24:42 PM »
Look at the 2nd one down under Muncie; It's yours...3885010 {M20}...Key on this link; http://www.camaros.org/trans.shtml#4speed
I did get your other pics. I'll have them posted in a few.
« Reply #22 on: April 15, 2012, 11:32:02 PM »
Yes - If the rpm drop from 1-2, 2-3, and 3-4 shifts is pretty much the same, it's an M21; if the rpm drop at 3-4 is significantly more than from 1-2 or 2-3, it's an M20.
IZRSSS
  • Guest
« Reply #23 on: April 16, 2012, 12:13:41 AM »
Here are three of your four other pics. I'll work on the POP in the next day or so. Right now I have a date with my son, easy chair, and the Yankees and Angels. We're headed up to Cal next month to see them live so this is kind of a precursor. ;)
IZRSSS
  • Guest
« Reply #24 on: April 16, 2012, 12:14:11 AM »
mopar346
« Reply #25 on: April 16, 2012, 12:55:59 AM »
Could it be a M20 case with M21 guts or aftermarket gear set? Not up on Muncies as far as what will interchange, I know you cant mix and watch but could you change all the innards?
IZRSSS
  • Guest
« Reply #26 on: April 16, 2012, 03:29:16 PM »
Kevin- Here's your POP (could not find RPO U15- Speed Warning Device). I don't think I have ever seen a closer car and engine build date; Car-10D, Engine-10/25.
Your "Guards, door-edge" is RPO B93
BTW, If you get some time and figure out this posting pics thing, would you mind posting your L48 on this thread? http://www.camaros.org/forum/index.php?topic=8314.0. This link might help you with posting pics; http://www.camaros.org/forum/index.php?topic=7215.0. Or, this one; http://www.camaros.org/forum/index.php?topic=4896.0
« Last Edit: April 16, 2012, 04:09:41 PM by IZRSSS »
tmodel66
« Reply #27 on: April 16, 2012, 04:33:56 PM »
I always thought 4P was the code for SS350 not just a radius rod. L30/M20 also got the 4P but we know in this case it's not an L30 car so the 4P code would indicate SS350.
Daniel
crobjones2
« Reply #28 on: April 16, 2012, 08:43:34 PM »
something doesn't add up - correct me if I'm wrong
a 350/ 295 would have a 4BBL carb - but POP indicates a 2BBL
Chris
69 SS 350
« Reply #29 on: April 16, 2012, 08:53:24 PM »
Marty just made a typo.  It should be a R instead of a B for the carburetor code as Kevin has noted in reply #5 above.  R would make it a Quadra-Jet.
