Author Topic: 1969 Z28 Camaro master cylinder  (Read 8467 times)
wisemanz28
« on: April 09, 2012, 10:22:24 PM »
I have my orginal master cylinder thats off my 1969 camaro Z28. What is the proper procedure for bench bleeding this master cylinder with bleeder screws?
NoYenko
Re: 1969 Z28 Camaro master cylinder
« Reply #1 on: April 10, 2012, 01:16:18 AM »
The way I bench bleed the master is with 2 old cut off brake lines with hoses attached going back into a full master reservoir. You can see the air pumped out of the hoses as you depress the piston several times. Then you mount the master on the car and flush & bleed the system go back and open the master bleeder screws for any residual air.  George
« Reply #2 on: April 10, 2012, 03:31:27 PM »
Here's a photo of the bench-bleed setup I use on my '67 Corvette master cylinder. Forget the bleeders on the master cylinder - just use the setup as shown and stroke the piston until the fluid runs free of air bubbles.
« Reply #3 on: April 10, 2012, 05:17:29 PM »
Nice setup JohnZ!    :)
Where does one find those neat little hose adapters?   or did you have to make them yourself?  :)
« Reply #4 on: April 10, 2012, 05:32:46 PM »
Stingr69
« Reply #5 on: April 10, 2012, 06:52:05 PM »
I believe the bleeder screws on the original master cylinders were only used for production line purposes and never used in service.
-Mark.
« Reply #6 on: April 11, 2012, 03:46:09 PM »
-Mark.
We didn't use them in production, and we didn't use the bleeders at the calipers and wheel cylinders either; we evacuated and filled the brake system through the little compensating port in the bottom of the master cylinder reservoir.  :)
Stingr69
« Reply #7 on: April 12, 2012, 03:41:04 PM »
-Mark.
-Mark.
Thanks for the correction John.  I am sure you are right.
