Author Topic: original A212CW for a 69 01B  (Read 16654 times)
DavidS
  • z28.net
    • www.z28.net
« on: March 31, 2012, 04:51:45 AM »
For a 1969 Z/28, 2nd week of January (01B) what A212CW filter is correct?  JohnZ has posted A212CW photos on this site in the past, but the links do not work any more.
#1) On Yenko.net: http://www.yenko.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=359461
This one came in a box dated 11/12/1969
Side View:
Top View:
#2) On 1970z28camaro.com: http://www.1970z28camaro.com/requests/
This assembly-line original one is from a 3rd week of March 1970 Z/28.
Side View:
Top View:
#3) On Camaros.net: Link: http://www.camaros.net/forums/showthread.php?t=164146&page=4
JohnZ has a side view of one from 1967:
It looks like #1 and #2 match, but #3 is very different with the straight wire.
Re: original A212CW for a 69 01B
« Reply #1 on: March 31, 2012, 10:58:33 AM »
Not the same part# but similar air filter. I thought 69's had the sq. type mesh and embossed part #.
Thought service replacements have both stenciling and changes in wire & configuration.
My examples:
The heavy mesh-
Here is one on ebay for sale that has a box dated past mid 70's! Notice how the sq wire runs different from JohnZ's pic.
http://www.ebay.com/itm/260988334111?_trksid=p3984.m1423.l2649&item=260988334111&viewitem=&sspagename=STRK:MEWAX:IT&vxp=mtr
« Last Edit: March 31, 2012, 11:26:03 AM by 68camaroz28 »
L78 steve
« Reply #2 on: March 31, 2012, 03:46:03 PM »
The chicken wire version in the above ebay auction I remember from the 70's.
69 Z/28 Dover White. SOLD
DavidS
  • z28.net
    • www.z28.net
« Reply #3 on: April 01, 2012, 01:51:49 AM »
Since the dates on the box on the EBay one go up to 1978, I would guess the EBay one is from 1978 or 1979.
I also have never seen any postings where original A212CW's were embossed on the top.  Everything I have seen says that the original A212CW's had white silkscreening starting with "BEST WAY TO PROTECT" on them.
I think the Corvettes were similar and I found something on the "Corvette Restoration Guide, 1968 - 1982" by Richard Prince.
“All 1968 and 1969 Corvettes not equipped with an L88 or ZL1 use an open element air cleaner assembly.  The assembly is comprised of a base, an element, and a lid.
  ……………etc etc.
Original air filter elements have ‘BEST WAY TO PROTECT YOUR ENGINE – REPLACE WITH TYPE A 212 CW’ silk screened in white around the horizontal lip.   Furthermore, original elements, unlike later replacements, have a fine wire screen around the outside.  Most replacements use a noticeably heavier wire.  Earlier cars probably utilize an element with the wire screen in a diagonal pattern.  Later cars probably use an element with the wire screen in a horizontal pattern.  With a horizontal pattern, the wire forms rectangles with the longer measurement running vertical when the element is installed.”
« Reply #4 on: April 01, 2012, 02:39:44 AM »
Interesting for sure. The examples I submitted were air cowl plenum filters. The heavier wire one with embossed was a very old filter with the NOS service replacement next to it.
DavidS
  • z28.net
    • www.z28.net
« Reply #5 on: April 01, 2012, 01:57:50 PM »
Every time I think something should be simple, it ends up more complicated than I ever thought it would be.  I also think I wrote my initial post in a confusing way.
Maybe a better way to ask is.......which filter wire on a A212CW is correct for a January 1969 Z/28 with no cowl?
Should it look like this late 1969 version?
Or should it look like the 1967 version?
« Reply #6 on: April 01, 2012, 05:46:58 PM »
For this sort of question I prefer to rely on vintage road test photos.
Both Hot Rod [1-69] and PHR [4-69] tested the same very early production '69 Z/28. The PHR engine photo clearly shows the soldered diamond mesh version as seen in photo #2. '68 Z/28 tests show the same mesh.
Car Life [8-69] and Road Test [8-69] tested the same yellow/yellow JL-8 Z/28. For the C/L test it had a cross-ram. But it was all OE for Road Test. The photo shows the mesh as in photo #2 but it appears to be oriented 90º from the photo. It is definitely not the diamond mesh. The earliest yellow interior cars were mid-February.
You could probably use either.
DavidS
  • z28.net
    • www.z28.net
« Reply #7 on: April 01, 2012, 06:21:11 PM »
THANKS William!!!!!  You rule.
I have the 1-69 Hot Rod and I think I was making myself blind staring at the tiny engine picture on page 33.
From your info, I just ordered the 4-69 PHR off EBay but did not find the 8-69 Road Test.....yet.
« Reply #8 on: April 01, 2012, 06:40:16 PM »
Road Test is really hard to find. Also notice the "reverse-polarity" battery.
Here's the photo.
DavidS
  • z28.net
    • www.z28.net
« Reply #9 on: April 01, 2012, 07:36:26 PM »
Thanks again William!!!!!
I think I understand what you are saying....that it looks like the 1969 version, but the mesh is rotated by 90 degrees.
Again, THANKS.  This kind of stuff is keeping me up until 2 in the morning doing non-stop searches!
DavidS
  • z28.net
    • www.z28.net
« Reply #10 on: June 08, 2012, 06:06:55 PM »
Here is a picture from the April 1969 PHR.
I found one that I believe is a perfect match.  The only problem with it is that the filter paper looks brown.  I'm not sure if it's dirty or just from age.  I am guessing it's from age since the filter paper looks like it's the same color as the first post of this thread #1 (filter on yenko.net) and #2) (filter on the 1970 Z/28) .
« Reply #11 on: June 09, 2012, 04:39:28 PM »
The original production-line filters had yellowish/brownish paper, as the paper was oil-wetted; later Service replacement A212CW filter elements weren't oil-wetted, and the paper was white.
DavidS
  • z28.net
    • www.z28.net
« Reply #12 on: June 10, 2012, 01:13:59 AM »
Thanks John!  I had been trying to think of a way to lighten it up by cleaning it somehow, to make it a light yellow, but now I think I'll just leave it alone.  I hope to have the 69 Z/28 ready for next years Camaro Nationals.
« Reply #13 on: October 07, 2019, 09:29:14 PM »
Ok, so what filter would be correct for a late 08C Z/28 then?
« Reply #14 on: October 07, 2019, 10:20:13 PM »
The filter in the first pic.
