Author Topic: 67 CAMARO CALF TRIM TAG  (Read 35724 times)
CROSSRAMJL8
Re: 67 CAMARO CALF TRIM TAG
« Reply #30 on: March 22, 2012, 03:19:49 AM »
Passenger side
CROSSRAMJL8
« Reply #31 on: March 22, 2012, 03:23:14 AM »
drivers side
CROSSRAMJL8
« Reply #32 on: March 22, 2012, 03:27:31 AM »
head pipes
CROSSRAMJL8
« Reply #33 on: March 23, 2012, 06:53:45 PM »
powerglide t7e 24n
« Reply #34 on: March 24, 2012, 07:33:08 AM »
That's dated correctly for the car. Looks like a good project for someone...
MO
« Reply #35 on: April 07, 2012, 11:22:28 PM »
Just wondering if your car has power brakes; are the fronts disc or drum?
CROSSRAMJL8
« Reply #36 on: April 14, 2012, 04:57:52 AM »
THIS HAS DRUM BRAKES
MO
« Reply #37 on: April 15, 2012, 06:22:59 PM »
Searching the CRG site shows your QS axle to be 3.07 with standard brakes. I have seen printed elsewhere that QS axles are metallic brakes. Have you checked that?
CantRepeat
« Reply #38 on: June 10, 2024, 09:53:15 PM »
Fisher did not care one bit which engine went into a car, everything engine related was installed by Chevrolet.  Fisher added the parts some of the cars needed.  If a car needed a 3 speed, or 4 speed transmission, fisher had to cut the hole for it, if the car was an RS, fisher had to attach the right rear tail panel and punch the correct holes for wiring and trim.  As far as the 4'so, 4P literally means it got the engine reinforcement plate under the rear seat on the passenger side.  4L is engine reinforcement with Z28 stripes on the trunk panel, 4N, and 4K is an engine reinforcement and black tail panel.  There is lots of discussion on why the 4K exists, but there either was supposed to be some difference between the L78 and L35 that was never implemented, such as two traction bars, or there actually is some difference in the structure of the bodies, that no one has been able to find yet.  4F is the remote mirror, which required a different hole drilled in the door to pass the cable thru.  Nothing in the codes specify a specific engine.  All small blocks are the same size, as are the big blocks so there would be no physical difference needed to be incorporated into the body to support one engine over the other as far as fisher was concerned.
This car could also have a fisher coding error, instead of Chevy putting the wrong engine into a non SS, in that they did not install the SS components into a car ordered that way, and chevy added all of their SS related hardware, per the broadcast sheets.  Things did go awry every so often in the plant.
If this is the case and service bulletin for radius rods is dated May 12, 1967 but there are tons of 4PLNK cars produced before the radius rod was introduced to production.
http://www.camaros.org/radiusrod.shtml
http://www.camaros.org/pdf/TSB_67-T-30.pdf
How can an Nov built SS 350 car have a 4P but no radius rod?
-Tim
Butternut1967
« Reply #39 on: June 12, 2024, 03:35:10 AM »
I have an 11A built LA car. It has the 12 bolt differential but no bracket mounted to the axle for the traction bar. I don't think they started adding the bracket to the axle until mid December of 66. Car is a factory 350 without radius rod.
1967 Camaro RS/SS Convertible 11A WXDL 2ELGR 3SL 4P 5Y
Rebuilding of 1967 RS headlight motors
CantRepeat
« Reply #40 on: June 12, 2024, 07:41:26 AM »
Does it have 4P on the trim tag or the reinforcing plate under the rear seat passenger side?
« Last Edit: June 12, 2024, 08:42:00 AM by CantRepeat »
-Tim
