Author Topic: 67 CAMARO CALF TRIM TAG  (Read 35723 times)
CROSSRAMJL8
« on: March 14, 2012, 10:12:11 AM »
I have a 67 camaro, LA car # matching. It is a SS but the trim tag dose not have the 4p? Is this normal?
Re: 67 CAMARO CALF TRIM TAG
« Reply #1 on: March 14, 2012, 11:17:25 AM »
 Is there anything in the 4 section? What is date period (month number / week letter) stamped on the tag? It would be better to post a close up of the tag for a better analysis.
CROSSRAMJL8
« Reply #2 on: March 18, 2012, 05:53:58 AM »
HERE IS THE TRIM TAG
CROSSRAMJL8
« Reply #3 on: March 18, 2012, 05:59:17 AM »
I have another post about the rear endQS 0601g2 in the decoding section? i do not understand the 6 after paint code- car came with white vinyl top?
Mark
« Reply #4 on: March 18, 2012, 12:48:50 PM »
1 = Chevrolet
2 = Camaro
4 = 8-cylinder engine
37 = coupe body
7 = 1967 model year
L = Los Angeles, CA assembly plant (Van Nuys)
160666 = vehicle serial number sequence
Decode for body number: 020107
06B = Built the Second week of June.
67-12637 = Custom Interior Coupe.
LOS = Built in Van Nuys California.
797 = Custom Parchment/Black Bucket Seats.
Z = (A50) Strato Bucket Seats.
N-6 = Lower Color is Madeira Maroon and the Vinyl Top Color is White.
G625 = internal plant scheduling code.
Options:
1E = (A01) Tinted All Glass
1L = (A67) Fold-down rear seat
2E = (C60) Air Conditioner
2M = (M35) Powerglide Transmission
2G = (D55) Console front compartment
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
« Reply #5 on: March 18, 2012, 01:23:09 PM »
 So the engine code shows it's a 350/295 L48/automatic and the rear shows it's a 12 bolt non-posi.
What is interesting is the trim tag is missing the 4P code.
Here is a quote from the CRG indo: "The 4P code was not used at the start of production at either the Van Nuys plant or the Norwood plant.
Van Nuys started using the 4P code on the SS350 cars in September, but Norwood didn't start using the 4P code until October. Early Van Nuys SS350 cars and Norwood SS350 cars built before October will not have the 4P code to verify that they are SS's
 This is looking like you car is an exception to this finding being yours is mid June 67 (Kurt?). Then again, with a VIN sequence of 666 anything is possible  :D
The engine assembly is March 23rd. Early for a June build but it is possible it sat that long.  Both my 67 BB's sat about 2 months before being installed.
If you can dig into the block casting dates and numbers (intake, block, distributor and even heads if you want to pull the covers) that would present a clearer picture of what you have.
The June 1st rear date range is good. Is there a rear factory traction bar on this car?
Per the CRG end of month VIN report, the160666 falls in the June period, which is good.
As you can see, a picture can show us a lot!
CROSSRAMJL8
« Reply #6 on: March 18, 2012, 02:12:49 PM »
Thr rear end has the bracket for the bar but there has never been on installed. Also the place where the bracket would be in the floorbaord is missing. It was never installed, no holes nothing. I will get the dates on the other engine parts and post them with some pictures. Thanks
Mark
« Reply #7 on: March 18, 2012, 03:20:18 PM »
Thats because the 4P code was one of the instructions to add the plate on the floor for the traction bar.  Without those instructions to Fisher you don't get the plate added to the floor.  Think someone pulled the wrong engine on the line, and it got installed.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
CROSSRAMJL8
« Reply #8 on: March 18, 2012, 03:26:52 PM »
I thought the 4p stood for SS350. are you saying the 4p only meant it had a traction bar? Can you clarify this for me?
CROSSRAMJL8
« Reply #9 on: March 18, 2012, 03:30:12 PM »
more pics
CROSSRAMJL8
« Reply #10 on: March 18, 2012, 03:35:47 PM »
Traction bar
CROSSRAMJL8
« Reply #11 on: March 18, 2012, 04:20:38 PM »
The car looks to be original paint with all the SS emblems ,bumble stripe, ss hood w/original hood insulation and springs, SS gas cap.
« Reply #12 on: March 18, 2012, 04:54:27 PM »
Hi Tony,
   The casting dates look tight so that's a good sign. What are the head cast dates? Did you check the cast numbers as well to see if they are correct? So far everything looks good but it's fun to document the numbers. Per a UOIT (a document that is rare to find), that area of the plate where the engine code would be stamped is listed as the engine reinforcement assembly.
So, if Mark is correct with the traction bar plate installed vs. not installed, then that would make sense why yours doesn't have the code stamped.
So far,  based on what you have presented, it looks like the car is authentic. I guess other cars built with that power train combination would have to be sampled to make that a definite conclusion.
Do you have other documentation such as a POP?
CROSSRAMJL8
« Reply #13 on: March 18, 2012, 07:40:38 PM »
I have the owner history. I am the 3rd owner. The original owner is dead. No paperwork. When I purchased the car I did not get the heads with it, all casting # are correct. There were several small peices missing ac brackets drive shaft etc. One other thing I thought was odd is the seat belts are the 68 & 69 design also look to be origianl to the car. Any idea where a build sheet might be in a LA car?. It still has the origianl carpet in it. Thanks for the information.
Tony
« Reply #14 on: March 18, 2012, 08:45:00 PM »
The build sheet *may* be above the gas tank though I have never seen one myself. I found the UOIT on my LOS car taped to the tunnel on the drivers side under the carpet along with an electrical inspection tag.
I was told these are rare to find however so I got lucky to have one with my car and it's the only documentation I have to show it is what it is.
