Author Topic: RS headlight assembly shims  (Read 6464 times)
scoop
« on: February 29, 2012, 02:52:47 AM »
What are the correct shims for adjusting the Rally Sport headlight assembly's? There was a Camaro at the Nationals last year that got charged points for using a body shim for the assembly.  Any help would be greatly appreciated.  Thanks, Scoop
big iron
Re: RS headlight assembly shims
« Reply #1 on: March 01, 2012, 12:34:39 AM »
67AIM Z22 B5 #2 3903452 Do not have a picture of one but the shim is for a 5/16 screw. AMK does not produce them.
Should not be hard to make using the picture if you need them.
Bob
scoop
« Reply #2 on: March 01, 2012, 02:31:50 AM »
My car is a 68 so I dont't have the 67 manual and cannot find a picture in my 68 Assembly manual. Would it be possible to post a picture? Would these be phosphate finished?  Thanks for the reply, Scoop
a
« Reply #3 on: March 01, 2012, 06:08:24 AM »
#5?
big iron
« Reply #4 on: March 01, 2012, 04:44:02 PM »
Scoop,
I would think they are phosphate as other body shims have that finish.
Bob
« Reply #5 on: March 01, 2012, 05:51:55 PM »
OK I looked in my AIM and if the shim you're looking for is #5 above, it looks like the shims that are used for alignment on the upper control arm but it is not the same part #.  I can't find that part # any where else, but I haven't looked that hard.  I looked at AMK and they don't have that part #.  The shims they have are on page 186 of their catalog and looked to be metal colored.  The part # you're looking for is 3903452.
scoop
« Reply #6 on: March 10, 2012, 12:49:05 AM »
Thanks Everyone for the information
bowtie68iho
« Reply #7 on: June 06, 2012, 03:55:42 AM »
Scoop,
I am probably the person you were referring to that got the points taken off at last year's Nationals for the wrong RS headlamp shims.  Well, I found the correct shim (see photo below) and showed it to a Legends Judge along with illustration #5 depicted on Page Z22/A7 of the 68 AIM.  It is not the same shim as those used for alignments.  The alignment shims are silver-colored and have a square-shaped tab.  The judge did say that the RS headlamp shim should be dark phosphate, just like the body shims.  Therefore, the plating in the photo below is incorrect.  I happen to have 8 phosphated shims for my car and 22 extra (unplated, raw steel) ones that I could sell for $10.00 each, plus S&H, if you or anyone else is interested.
Bernie
68 NOR SS/RS L48/M35 Convertible
Cordovan Maroon - Special Paint Exterior (black stripes)
Black Custom Interior
Silver Concours (Legends Class) at 2012 Camaro Nationals, Gold Concours at 2014 MCACN.
