Author Topic: coil spring ID  (Read 5790 times)
coil spring ID
« on: June 30, 2006, 03:25:10 AM »
Anyone know what a 3955725 coil spring fits? Or what the rate is?
Re: coil spring ID
« Reply #1 on: June 30, 2006, 03:46:53 AM »
James,
The 3955725 was coded "HB", has a rating of 345 pounds and was used in the following applications:
1969 Camaro Coupe Standard Front Spring for L34, L35 and L78 cars, 345-426 pounds over stock weight
1969 Camaro Convertible Standard Front Spring for L34, L35 and L78 cars, 263-344 pounds over stock weight
1969 Camaro Coupe Heavy Duty Front Spring for L48 and L65 cars, 345-426 pounds over stock weight
1969 Camaro Coupe Heavy Duty Front Spring for Z28, 263-344 pounds over stock weight
1969 Camaro Convertible Heavy Duty Front Spring for Base Engine (without JL8), 263-344 pounds over stock weight
Re: coil spring ID
« Reply #2 on: June 30, 2006, 07:06:44 PM »
They are in the Black 69 RS/Z that is an original paint car... just wondering
