Author Topic: Alternator bracket spacer  (Read 4880 times)
Camaroon
« on: February 17, 2012, 02:18:21 PM »
Please see picture of spacer located between upper alternator bracket and water pump observed on a 69 Camaro small block.
Does this look correct and was this spacer originally installed at the factory?
Gramps69Z
  • 69 X33 D80
Re: Alternator bracket spacer
« Reply #1 on: February 17, 2012, 02:33:28 PM »
Nope! No spacer for the upper bracket.
Captain John Wykoff
x77-69z28
« Reply #2 on: February 17, 2012, 04:36:21 PM »
the water pump was replaced, with a generic replacement. with the original gm pump you will not need this.
srode
« Reply #3 on: February 18, 2012, 01:01:08 AM »
Its a water pump housing with the mount for the alternator bracket located like a 76-84 small block - they were set back closer to the block and use a different upper bracket.  Using a 69 bracket, you need a spacer on that pump, like in the picture.
