Author Topic: Where is the temp sensor located?  (Read 11663 times)
discobiscuit
« on: February 15, 2012, 01:56:18 AM »
Trying to find the temp sensor on my 67 Camaro with a 327.  I think it's supposed to go on the front of the intake just below the water neck but I've read a few articles saying some of them were located on the driver side engine block.  Thanks in advance for any direction.
Mark
Re: Where is the temp sensor located?
« Reply #1 on: February 15, 2012, 03:10:36 AM »
Drivers side head, between cylinders 3 and 5.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
1968 Z28
« Reply #2 on: February 15, 2012, 03:19:33 AM »
On a 1967 the AIM shows the sensor in the front driver side of the intake manifold.  It was moved to the cylinder head on the 1968 models.
BTW.....it is UPC 12, sheet A9 on the AIM.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
MyRed67
  • SZZLN 67
« Reply #3 on: February 15, 2012, 06:56:45 AM »
If your '67 has original Heads there won't be a provision for it in the Head.  As you stated it should be in the Intake Manifold by the Water Outlet.  To my knowledge they were never in the side of the Block.
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
elcamino72
    • More Information on Camaro Fraud
« Reply #4 on: February 15, 2012, 02:57:47 PM »
I believe this is one of the difference between 1967 intakes and 1968 intakes.  The later does not have the drilled hole for the coolant temp sending unit it being instead in the driver's side cylinder head.
flyingskibiker
« Reply #5 on: February 16, 2012, 03:31:58 AM »
My 11/15/67 '1069' still has it...  I believe '68 was a "change over" year?
69pace
    • TeamCamaro - Moderator
« Reply #6 on: February 16, 2012, 05:37:34 AM »
Yeah Dean yours is not in the head, only 69 I think, maybe late 68's.
pjbizjak
« Reply #7 on: February 16, 2012, 02:09:28 PM »
67's had the sensor in the intake manifold next to thermostat water neck. 68's had the sensor in the driverside cyl head. It's possible that late build 67's could have the sensor in the head.
L78 steve
« Reply #8 on: February 16, 2012, 04:28:40 PM »
The early 291 heads had the boss for the temp sensor but wasn't drilled and tapped, I have a set of these. The change over was for early 68.
69 Z/28 Dover White. SOLD
« Reply #9 on: February 16, 2012, 04:50:04 PM »
On 327 '67 Corvettes, the 291 heads began to appear in March-April '67; they had the boss, but it wasn't drilled. At '68 start of production, the boss was drilled/tapped and that's where the temp sender was installed; there was no provision in the '68 intake for the sender.
flyingskibiker
« Reply #10 on: February 17, 2012, 05:13:20 AM »
BBC must be different, as per my '68 model year intake.
« Reply #11 on: February 17, 2012, 05:14:26 AM »
Since it affected service and wiring, it would make sense that they timed the change to the model year. It wasn't fixing a big problem, so it wasn't worth doing as a mid-year running change.
flyingskibiker
« Reply #12 on: February 17, 2012, 05:39:17 AM »
Yah, it's all over the place.  My 10/12/67 '9852' doesn't have it...  Though, it is a "newer" design for that year.
