Author Topic: Alternator Belt 69 Big Block without AIR pump  (Read 7119 times)
adams69camaro
  • My 69 L-78 Convertible Re-Creation
« on: February 14, 2012, 12:29:28 AM »
Anybody know the correct alternator belt for a 69, 396/375 without air pump?  Just water pump, fan and alternator with deep groove pulleys.  I don't see one listed in the restoration parts books.
Re: Alternator Belt 69 Big Block without AIR pump
« Reply #2 on: February 14, 2012, 01:16:35 AM »
You don't see it listed because there isn't one. The 69 Camaro big block engines all came with the smog pump and for the L78, the belt went around the crank pulley, the alternator pulley, the water pump pulley and the smog pump pulley. The AIM shows the routing on UPC L78, sheet A6 and the belt was P/N 3921934.
(By the way, the 63 amp alternator wasn't available on the L78.)
THIS is the belt you need, but again, you have to have the smog pump installed. (And save your money. From a very reliable source, these belts aren't very good.)
chevonly
« Reply #3 on: April 07, 2012, 04:13:05 AM »
This is the belt I put on,a dayco top cog 45 inches long,got it at Summit Racing cause couldn't find one locally.Their part # DAC-15450. Dayco belt is 11mm wide compared to 10mm gates belt. I was having slippage on alt. pulley with the thinner belt. Just put it on ,we'll see how it works.  69 L78
