Author Topic: Convertible Top Restoration  (Read 4463 times)
68rs327conv
    • The build
« on: February 06, 2012, 05:50:11 PM »
I am in the process of removing my convertible top pump motor, cylinders and lines, as car will be heading to the body shop next month for a date with the rotisserie. The top worked fine before and I see no evidence of any leakage, but it was slowing down a bit when it was put up, but I have never checked the fluid and doubt it has ever been serviced.
My question is should I clean up the exterior of the parts myself and reinstall, or spend the extra money and have the pump sent out for a rebuild and replace the cylinders.
Your opinion is greatly appreicated
68 RS Conv 327/210hp, Powerglide Factory AC
Re: Convertible Top Restoration
« Reply #1 on: February 06, 2012, 11:07:54 PM »
 The last time my top did that I found the fluid was a tiny bit low in the pump. I drained it and refilled it with automatic tranny fluid and it worked perfect.
