Author Topic: 1969 ORIGINAL Z-28 CAMARO ''ENGINE FRAME MOUNTS'' WITH ""DZ'' 302  (Read 7920 times)
penard
WE HAVE A IMPORTANT QUESTION !!
IT IS A NORMAL THAT THE ''ENGINE FRAME MOUNTS'' AT RIGHT ( PASSENGER SIDE ) IS MORE HIGHER THAT THE LEFT ( DRIVER SIDE ) ??
WE NOT SHURE IS THAT OUR ''ENGINE FRAME MOUNTS'' ARE CORRECTLY TO INSTALL FOR THIS MOMENT ??
BECAUSE , THAT DRIVES THE ENGINE TOWARDS THE LEFT ??
HOWEVER , OUR ''ENGINES FRAME MOUNTS'' HAVE 4 SMALL MARKS ON THE TOP , AND ACCORDING TO WHAT TO HAVE READ , ONLY THE ''ENGINE FRAME MOUNTS'' FOR Z-28 1969 HAS THESE SMALL MARKS ?? !1
AND MOREOVER , THAT OUR ''ENGINE FRAME MOUNTS'' OF LEFT HAS THE SMALL HOLE FOR THE ''CLUTCH RETURN SPRING'' !!
PLEASE , GIVE ME LET US CAN HAVE TO US AN ANSWER CLEAR CONCERNING THIS QUESTION, BECAUSE WE DO NOT UNDERSTAND WELL WHAT IS WRITTEN ON THE SITE OF ''C.R.G'' :-(( !!
AND  MOREOVER , ON THE IMAGE OF THE SITE IT SHOWS THE ''ENGINE FRAME MOUNTS'' OF THE BIG BLOCK WHICH THEM ARE HIGHER ON THE LEFT ( DRIVER SIDE ) WHAT MOVES ENGINE TOWARDS THE RIGHT , THUS OPPOSITE AS OF OUR ??
I WAIT YOUR ANSWER , THANK PAUL
PS ; SEE THE IMAGE OF OUR CAR FOR SEE THAT !
Re: 1969 ORIGINAL Z-28 CAMARO ''ENGINE FRAME MOUNTS'' WITH ""DZ'' 302
« Reply #1 on: February 02, 2012, 05:05:36 PM »
'69 Camaros [8 cylinder] used 3 distinct frame brackets:
307/327
302/350
396/427
The frame brackets only work with the motor mount designed for it.
307/327 originally used the non-interlock mount.
302/350/396/427 used the thicker interlock mount.
You CAN NOT mix any of these components.
Having said that I have no idea what the motor mounts in the photo are for. 73-74 Nova? They used a completely different frame bracket. My guess is the AutoZone guy sold you the wrong motor mounts.
« Reply #2 on: February 02, 2012, 05:44:32 PM »
I suspect lots of us have learned this lesson the 'hard way'....  :)
sam
« Reply #3 on: February 03, 2012, 12:06:44 AM »
I believe the 69 Z/28 frame mounts should have 507 and 508 as a part number on them.
red69
« Reply #4 on: February 03, 2012, 03:24:41 PM »
69 302's didn't have interlock mounts from the factory did they? I had to take mine in for a recall, the dealer installed them.
« Reply #5 on: February 04, 2012, 03:28:54 PM »
Even though the 302/350 frame stands were designed for the interlock mount, those cars were involved in the recall.
The frame brackets in the photo are clearly different heights. 302/350 brackets are the same height. Unless corrected nothing will fit properly; exhaust, clutch linkage, shifter, hoses, fan shroud.
L78 steve
« Reply #6 on: February 04, 2012, 07:58:31 PM »
Looks like BB mounts switched left for right if thats possible.
69 Z/28 Dover White. SOLD
