Author Topic: Dash Panel Mystery  (Read 9330 times)
DavidS
  • z28.net
    • www.z28.net
Dash Panel Mystery
« on: January 21, 2012, 06:04:53 PM »
A few weeks ago I bought a sheet metal "PANEL, INSTRUMENT" part number: 8716458, group: 10.230
When it came in, it looked like a section was removed.  It did not match the original dash panel that was in the car.
It looked like this:
I became upset and returned the dash panel to the seller.
Now, I see another different NOS dash panel on EBay that looks identical to the one I returned
EBay Dash Panel
EBay auction: http://www.ebay.com/itm/1969-Camaro-N-O-S-Dash-Panel-/320830957170?hash=item4ab303e672&item=320830957170&pt=Vintage_Car_Truck_Parts_Accessories&vxp=mtr
My original dash panel looks like this:
Did the over the counter dash panels have that section removed for some reason???
copo
Re: Dash Panel Mystery
« Reply #1 on: January 21, 2012, 07:36:22 PM »
That PANEL, INSTRUMENT" part number: 8716458, group: 10.230 is for a Nova, I am not sure what year it fits, but going by the speaker grill opening I would say mid to late 70's.
DavidS
  • z28.net
    • www.z28.net
« Reply #2 on: January 21, 2012, 08:05:55 PM »
Wow!
Thanks COPO.
So both the 69 Camaro and the 70's Nova used the identical part number.  That is confusing!
Whoever ends up buying the EBay Nova one is going to be upset.
DavidS
  • z28.net
    • www.z28.net
« Reply #3 on: January 22, 2012, 01:35:24 AM »
I could not find anything on the net on 8716458 being used on Novas and Camaros.  Is there any documentation on this?
I found a posting on Yenko.net where a guy had the exact same problem about 8 years ago.  Weird.
« Reply #4 on: January 23, 2012, 05:04:27 PM »
Not true. The Nova dash does not have the two square cluster mounting holes next to the ash tray opening.
That was how you had to repair a rusty Camaro dash back then. Use the Nova part ['69-'79] and slice off the top. And correct the speaker grille.
DavidS
  • z28.net
    • www.z28.net
« Reply #5 on: January 24, 2012, 03:41:06 PM »
William, THANKS for the clarification.  However, I still am confused about 8716458 which is supposed to be the correct panel.  I have seen 3 cases where 8716458 panels in the original box do not match what is originally on the car.
Is the over the counter panel just not 100% visually correct but functionally A-OK?  Was the over the counter panel supposed to be modified?
« Reply #6 on: January 24, 2012, 05:16:09 PM »
I worked in a Camaro business from 1983-1997. We did a weekly GMPD order as many parts were still available during that time. GMPD regularly substituted parts. Here's a few I remember:
'68 Z/28 rocker covers - sent chromed '69s
2 piece rotors - sent later 1 piece
'69 Camaro 396 emblem - sent '70 Nova emblem
'68-'69 rear spring anchor - sent '70 Camaro version w/sway bar bracket
12 bolt axle cover - sent '70 version with notch for bracket
Certain parts were never serviced, particularly plastic interior parts in colors other than black. "Paint to match" I guess.
Late model stuff was worse. They would supply a generic fender; you would have to cut brackets off the original and weld them yourself.
Careful buying "NOS"...
« Last Edit: January 25, 2012, 01:49:00 AM by william »
DavidS
  • z28.net
    • www.z28.net
« Reply #7 on: January 24, 2012, 05:53:23 PM »
I worked in a Camaro business from 1983-1997. We did a weekly GMPD order as many parts were still available during that time. GMPD regularly substituted parts. Heres's a few I remember:
Ah.  Now that is clear!  Thanks!!!  I had been giving myself a headache trying to figure this out.
Kelley W King
« Reply #8 on: January 24, 2012, 06:19:45 PM »
Mid year corvettes were the same. If you ordered a grille or gas lid for any year they sent a 66 model. It seems if a later part fit they discontinued the others.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
