Author Topic: 67 Alt. Pulley 3844100  (Read 35597 times)
plumL78
Re: 67 Alt. Pulley 3844100
« Reply #30 on: February 11, 2012, 01:20:13 PM »
Yes Jeff you are correct . I will post another pic of the orig owner  07B five rivet small fan to. We think these parts came on the later L78s.  Jerry M has paper work from GM  that calls out for the big  clutch  for L78s but for sure not every car got it.  I believe the 04B 4Pcar  has the big fan.
plumL78
« Reply #31 on: February 11, 2012, 01:23:31 PM »
Here is the orig owner 07B small fan
jbtech
« Reply #32 on: October 26, 2021, 03:14:43 PM »
Thanks to this thread I've been able to confirm the correct part needed for my 67 L78 and got my hands one one. What a big difference between the L78 and Z28 Pulley.
Jose
67 Camaro L78
124377N212598
john302
« Reply #33 on: October 31, 2021, 07:41:57 PM »
If your L78 was built in La its a good chance that pulley is incorrect. Found three original La built l78s with a dual belt pulleys . Have photos to prove it.
john302
« Reply #34 on: October 31, 2021, 07:44:55 PM »
The dual pulley on the La built L78s has nothing to do with the smog system on the Ca sold cars.
« Reply #35 on: October 31, 2021, 10:08:55 PM »
His is a NOR car. And yes that has been discussed previously on either here or sYc.  It is a interesting topic regarding the double pulley.  Still have yet to determine the reasoning unless new information has come to light.
plumL78
« Reply #36 on: November 15, 2021, 10:28:50 PM »
i know  Larry C.  has talked  about  cars having the double pulley. There are around 5 survivor cars in the reg. and all have the 100 pulley. I believe they are all norwood cars
jbtech
« Reply #37 on: March 07, 2022, 05:00:43 PM »
I have received photos of my original L78 04D engine as pulled in the late 60's early 70's by the original owner. The pulley is definitely a 3844100. However it does NOT have a stamp but as previously discussed, later NOR cars appear to have a stamp. I include this data to prove early NOR L78 cars also used the 3844100 as illustrated in the AIM.
Jose
Jose
67 Camaro L78
124377N212598
