Author Topic: Is this the oil pressure line hole?  (Read 9514 times)
1967RS/SS
« on: January 10, 2012, 03:19:42 AM »
Is this the oil pressure gauge line hole and grommet just above the plastic ducting and to the right of the steering column boot?  The reason I am unsure is because my car also has an open hole behind the accelerator pedal.
1967 RS/SS L-48
Van Nuys 01C
Joseph
68Zproject
Re: Is this the oil pressure line hole?
« Reply #1 on: January 10, 2012, 05:02:07 PM »
If you mean the rubber thing, no.  That's what holds the firewall mat to the firewall. If you look from the engine side toward your firewall, you should see this rubber nib sticking out.
68Z28
big iron
« Reply #2 on: January 19, 2012, 07:33:58 PM »
Need info.
What is your build date?
Is the console w/ gauges original to the car?
Bob
68Zproject
« Reply #3 on: January 20, 2012, 04:37:52 AM »
Firewall side.
68Z28
big iron
« Reply #4 on: January 20, 2012, 07:14:36 PM »
Early 67's with U17 had a 2 pc. oil line with a bulkhead connector on the firewall. Was changed to a 1pc. line and rubber plug as shown around 05 or 06
of 67.
Bob
« Reply #5 on: January 21, 2012, 01:30:38 AM »
of 67.
Bob
I checked my NOR 67 with a trim tag date of 5B and the oil line is a 1 piece unit using the rubber grommet.
big iron
« Reply #6 on: January 21, 2012, 02:18:03 AM »
Do search ( oil lines for 67 cars with gauges ) . Check BrianK's reply #6 . Also discussed over on TC.
Bob
