Author Topic: hardware question  (Read 7037 times)
Steve Barndt
hardware question
« on: January 08, 2012, 12:30:40 AM »
Is there any "rule of thumb" to follow when buying hardware especially the more or less invisible kind? The first things I find I need are the 3892755 speednuts that hold the forward rear spring mounts in place. For something like that I wouldnt want to reuse original and care more for a quality product then a dead on original part.
I came up with some brake parts while rooting through my stuff. 5463565L & 5463566R brake backing plates and a 5460348 brake master cylinder and Delco Moraine power booster. Where would I look to see what these came off of? They look like someone reconditioned them. I am thinking they have to be Chevelle or A body parts.
thanks
MyRed67
  • SZZLN 67
Re: hardware question
« Reply #1 on: January 08, 2012, 03:26:10 AM »
To answer your first question about the 3892755 J-nuts, read this from another thread;
Don't replace the clip nuts with anything but the "CIP" branded ones. AMK sell them.
OER packaged clip nuts are rubbish.
http://www.camaros.net/forums/showpost.php?p=1288560&postcount=94
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
tmodel66
« Reply #2 on: January 05, 2013, 12:52:50 AM »
This an old thread but I need an answer on the backing plates. Are these 5463565L & 5463566R brake backing plates correct parts for '69 Disk set up.
« Reply #3 on: January 05, 2013, 02:41:36 AM »
Daniel, I don't think so! My 67-69 book states the original part # was 5463496 & 5463497 (two piece rotors). I believe the 5463565 & 5463566 were later designs used on other cars like Chevelles with a one piece rotor.
tmodel66
« Reply #4 on: January 05, 2013, 03:32:28 AM »
Thanks a lot Chick. I can't find my books since I moved everything from the shop back home when we finished my car.
