Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
General Discussion
Which head casting date is correct?
« previous
next »
Print
Pages: [
1
Author
Topic: Which head casting date is correct? (Read 4272 times)
Ramjett54
Member
Decatur Alabama
on:
January 04, 2012, 05:14:54 PM »
I have an 02e 1968 z28 what would be the correct date range for cylinder heads?
I found some a28 castings, would they be within range?
Last Edit: January 04, 2012, 05:40:55 PM by Ramjett54
Tweet
Logged
1968 Z28
Hero Member
Re: Which head casting date is correct?
Reply #1 on:
January 04, 2012, 06:19:05 PM »
Don't know what is considered acceptable but here is mine for example. Have an original 1968 07C Z28 that has an engine build date of 06-19 and the heads are dated E-9-8 and E-14-8.
Logged
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
Petes L48
Hero Member
Reply #2 on:
January 04, 2012, 06:24:22 PM »
Do you have the original block, or are you building a "date correct" engine? You should be comparing the engine build date (stamped, and assuming it is not a fake/restamp) with the head casting dates. Obviously the heads need to be cast earlier than when the engine was assembled. This old thread and links found within may help, I think it has generally acceptable date spans:
http://www.camaros.org/forum/index.php?topic=6256.0
Logged
x66 714
Hero Member
Reply #3 on:
January 04, 2012, 06:40:27 PM »
I have an 02E 68 z/28 & one head is "A" late & the other is a "B" early. Can you contact me at jiaccino@cox.net? I have aquestion for you also. Thanks, Joe
Logged
Print
Pages: [
1
« previous
next »
General Discussion
