Author Topic: Possible Purchase  (Read 28879 times)
69houdini
  • 69 SS X55 Butternut Vert / 68 Z28 Rally Green
Re: Possible Purchase
« Reply #45 on: January 13, 2012, 11:44:38 PM »
Paul, to the right of the steering column looks correct.
« Reply #46 on: January 13, 2012, 11:54:09 PM »
Correct, just be aware it doesn't prove the car is a Z/28, just that it came with a Muncie transmission.
High Temple, Lamanai, Belize
69houdini
« Reply #47 on: January 14, 2012, 12:00:21 AM »
Yes you are correct, everything that I checked and posted points to the real deal except for one glovebox sticker. All #s and date codes coincide, maybe I'll ask Tebow for guidance.
Gramps69Z
  • 69 X33 D80
« Reply #48 on: January 14, 2012, 02:01:36 AM »
I think we'll know if Tebow's for real after tomorrows game.  :D
Captain John Wykoff
« Reply #49 on: January 14, 2012, 11:57:25 AM »
Hi John and good luck with the purchase if not solidified yet. Read your post in the beginning but then did not follow up until now and was pleasantly surprised to see our 01B NOR 68Z has another sibling as our engine was built/born the same day. I have a restoration thread going that you might find interesting concerning our 68Z. http://www.camaros.net/forums/showthread.php?t=182584
69houdini
« Reply #50 on: January 14, 2012, 04:01:44 PM »
Cool thread, I have a butternut '69 convertible SS black top that I just adore. Since you are kinda my big bro { 01B - 01C } after seeing this thread what is your opinion about the tire pressure sticker? and the chances of this being a real Z28?
« Reply #51 on: January 14, 2012, 11:47:48 PM »
Well you sure have a lot of info that supports it is a Z/28 but as others have mentioned its always wise to proceed with caution. Concerning the sticker, I'm no expert but over the years we have all seen some weird things like a AM radio mast on a AM-FM radio equip. car or std. seat belts in a custom int. equip. car or a factory grind out and restamp of a pad so anything is possible and it might be just a simple defect that someone placed the wrong sticker or glove box door on.  Bottom line, you will probably never know.
69houdini
« Reply #52 on: January 15, 2012, 12:29:41 AM »
The dealer told me there is an imprint of the POP is available with this car. Is there anywhere on that imprint any code or numbers that would say this is a Z28 or has something only a Z28 would have. I'm not familiar with POPs enough to know how to break the options down or even if there are any #s that would verify this.
« Reply #53 on: January 15, 2012, 01:08:50 AM »
Quote
Yes, but post a picture. POP's are now being faked just as much as everything else.
