I'm curious what kind of oil would be leaking from a fuel pump? If they have 'sealed oil' inside of them, it couldn't be very much.. I'd have thought any internal lubrication would be a heavier grease, not oil? typically if there's oil leaking, it would be from the engine oiling system, running down the fuel pump push rod, and leaking from the gaskets on the cover plate or the gasket for pump installation. Engine oil can also leak from one of the front bolt holes that go into push rod the passage way; that hole needs a short bolt installed with sealer on the threads. In short, maybe you don't have a leaking fuel pump...
but instead a simple problem that you can address yourself...
