Author Topic: Engine Detailing "Tricks"?  (Read 32282 times)
lakeholme
  • 68-12D L30/M35
Re: Engine Detailing "Tricks"?
« Reply #30 on: December 31, 2011, 08:53:22 PM »
Sdkar, thanks for the information.
Dave, thanks for the clarification... When I need points with the wife, it usually involves a new car, not just a wash.   ;)
Daniel, I have used Back to Black. A little goes a long way. Yes, no residue.
I'm still looking for opinions on spray on engine dressing.  ??? ;D ???
« Last Edit: December 31, 2011, 10:28:40 PM by lakeholme »
lakeholme
  • 68-12D L30/M35
« Reply #31 on: January 03, 2012, 09:56:16 PM »
How about engine bay dressings like Sonus or Griots? Anyone use those?
lakeholme
  • 68-12D L30/M35
« Reply #32 on: February 15, 2012, 01:56:24 AM »
Most of the brushes mentioned in this thread are hard bristle. I've started using a soft bristle wheel brush, which does not scratch surfaces or undo connections.
I'm still looking for opinions for best engine dressing...
Any help or input is appreciated.
mickeystoys69RSSS
« Reply #33 on: March 11, 2012, 05:32:16 PM »
Here is what I use on my cars:
Front Compartment/Engine Bay
Meguairs All Purpose Cleaner
Various Brushes
Zaino All In One On All Painted Surfaces
Meguiars HyperDressing On All Hoses and Plastic Surfaces
lakeholme
  • 68-12D L30/M35
« Reply #34 on: March 29, 2012, 07:52:01 PM »
Beautiful day in NC, so I started my pre-Autofair clean up. I used Gunk Brite to clean the motor. Turtle Wax Wash, diluted, with a couple of different soft bristle brushes to clean everything but the electrical. That got wiped with a damp clean towel. So far so good.
Tonight, I'll work on the engine well shine -my original reason I started this thread. I'm using 303. It has always worked well on our boats and never gunked up or drawn dust.
Thanks to everyone for their input.
I'm planning on that getting me through till the Fall, including three shows, two tours, and as many cruise-ins as I can get to. If you don't drive it in the rain, they usually don't get that dirty.
tmodel66
« Reply #35 on: April 22, 2012, 12:05:59 AM »
I found a bottle or a tea glass washer with plastic handle and a foam head, like you use in the kitchen, is very good to clean in the door jambs. Fits into the door hinges and cleans pretty good. It also fits in between the fender and door when the door is open to clean the fold on the fender that you can see from inside thru the door jamb.
lakeholme
  • 68-12D L30/M35
« Reply #36 on: May 01, 2012, 12:36:26 AM »
Is anyone familiar with an engine cleaner called Nitro?
On a tour this  weekend, the Tri-Five owners said it worked well.
IZRSSS
  • Guest
« Reply #37 on: May 03, 2012, 11:32:51 AM »
Not sure if this is appropriate for this section but I have a question concerning power buffing/polishing the hood. Do you guys do this with the hood closed or partially open. If you do it with the hood partially open (as I do) what do you use if anything to prevent splatter into the engine bay? I go through the trouble of masking off the engine bay but was hoping for an easier solution.
tmodel66
« Reply #38 on: May 03, 2012, 02:31:10 PM »
Marty I use old newspaper. Tear a sheet in half and tape it to the edge of the hood long ways. Push the hood down and let the paper fold out over the fenders,cowl panel and valance panel. It isolates the hood and keeps all the compound on the outside. You'll have to put some on the corners after you close the hood but you can tape it to the other paper that's already there.
IZRSSS
  • Guest
« Reply #39 on: May 04, 2012, 12:54:27 AM »
Dan- My initiation spots were the engine compartment, cowl grills (got stuff inside the grills), the suspension & bottom areas in and around the radiator. It took me days to clean that mess up. Now I watch the buffers rotation and mask off the engine compartment. But I did it all on the inside placing tape around the each of the fenders, cowl & header. I have trouble getting a good seal around the hinges. Then I drop the hood where the bolt just penetrates the catch…then I take the rest of the day off. ;)
Your idea seems very effective and a lot quicker.
Thanks.
lakeholme
  • 68-12D L30/M35
« Reply #40 on: May 05, 2012, 08:19:02 PM »
Marty,
Other than compound splatter, what's the advantage to leaving the hood slightly open?
IZRSSS
  • Guest
« Reply #41 on: May 05, 2012, 09:17:53 PM »
For me it’s just a matter of preference. I found I had better control of the buffer with the hood partially open. Especially when approaching the edges.
lakeholme
  • 68-12D L30/M35
« Reply #42 on: May 05, 2012, 11:07:51 PM »
I see, thanks.  ;D
lakeholme
  • 68-12D L30/M35
« Reply #43 on: May 10, 2012, 12:46:36 PM »
