Author Topic: Plug wire supports  (Read 7852 times)
sixt9x33rs
Plug wire supports
« on: December 19, 2011, 02:49:27 AM »
Would these plug wire supports be correct for a 69 Camaro?
srode
Re: Plug wire supports
« Reply #1 on: December 19, 2011, 10:17:46 AM »
Yep, those are correct.
sixt9x33rs
« Reply #2 on: December 19, 2011, 12:47:49 PM »
Did you notice the front loom and the rear loom have angled supports?
srode
« Reply #3 on: December 19, 2011, 11:53:12 PM »
Yes, the front one is for the temperature sending wire, the back one is for the 2 plug wires from the 2 front cylinders.
sixt9x33rs
« Reply #4 on: December 20, 2011, 01:33:37 AM »
thanks
« Reply #5 on: December 20, 2011, 08:37:12 PM »
Actually, the temp sender wire goes in the center slot; see the Assembly Manual, UPC 12, sheet A7.
srode
« Reply #6 on: December 20, 2011, 10:33:16 PM »
My mistake not being more clear, I meant the ramp that points to the rear of the engine on the front bracket holds the wire.  I didn't notice the split in the middle of that bracket holds the wire also, but it does. Learn something new everyday.
69DuskBlueRS/Z28
« Reply #7 on: August 23, 2023, 01:39:46 PM »
Does anyone know the part number or a source to purchase the left outboard spark plug wire support (Cylinders 1 & 3) that also holds the temperature sending unit wire?  It is shown in "sixt9x33rs''s second photo, also shown on page 11 in Jerry's '69 book as well as UPC 12 sheet A7 on page 158 in the assembly manual.  Any help would be most appreciated.
« Reply #8 on: August 23, 2023, 05:39:41 PM »
These can be found by the millions of small block vehicles recycled or at swap meets.
I found these off of a 350 powered station wagon, stripped sent to plater now needed plastic coated. The tool handle dipping in a can product will work but is not meant for the heat and oil environment of an engine compartment. A true "Plastisol" dip would be best but difficult to source. *( the "can" will have to do)
aka: Military Specification Plastisol meeting MIL-P-20689 and A-A-59464. Automotive Specification Plastisol ESB-M4D148-A GM225M GM7001M and MS-DC513.
These might be repoped see Heartbeat Camaro as an option.?
Leon in Mn.
« Reply #9 on: August 23, 2023, 06:42:30 PM »
Looking for big block wire supports.  Although they are out there, I can't seem to find the correct ones for my 67.  Any ideas?
69DuskBlueRS/Z28
« Reply #10 on: August 23, 2023, 09:19:51 PM »
Thank you, 169Indy.
