Author Topic: Nos shifter ball  (Read 14764 times)
plumL78
Nos shifter ball
« on: December 18, 2011, 10:06:08 PM »
I bought some camaro parts and this shifter ball came with the parts. Does anybody know what it would have came on ,  It has a hole with  threads like a set screw  along with the hole in the bottom  . Thanks Kerry
Re: Nos shifter ball
« Reply #1 on: December 18, 2011, 10:14:42 PM »
1967 Firebird all with 4 speed and floor shifter. Note that this one (P/N 390768) was superceeded by 3921147 which also fit 67 Camaro 4 speed, 68-69 Camaro 4 speed floor shift w/o console, 68-69 Nova with 4 speed floor shift, 68-69 Chevelle with 4 speed floor shift and 68-69 Corvair with 4 speed.
However, yours is missing the chrome piece.
« Last Edit: December 19, 2011, 04:35:37 PM by Ed Bertrand »
1968 Z28
« Reply #2 on: December 18, 2011, 10:27:00 PM »
Found it on multiple listings....from Corvette to Oldsmobile and several others in between.  Looks like it was probably a replacement for various original knobs.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
plumL78
« Reply #3 on: December 19, 2011, 02:18:48 PM »
Ed  I don't believe this knob ever had the chrome bottom. The chrome bottom is for locking the ball in position. With the set screw hole the bottom isn't needed. I'm sure you guys are right as it most likely  generic  gm replacement
« Reply #4 on: December 19, 2011, 04:43:18 PM »
Quote
Yes, it did. It came that way from service. Production line knobs had two separate part numbers, but service combined these two parts into one number that included both the black knob and the chrome base. I'm not sure why yours has an extra hole drilled and taped in it unless it was done by a prior owner, but here's what should have been included in the box:
« Last Edit: December 19, 2011, 05:30:47 PM by Ed Bertrand »
plumL78
« Reply #5 on: December 19, 2011, 07:17:19 PM »
Ed what I'm saying it that this ball is different The chrome on the bottom of the ball won't fit this ball  . Here is a pic of a real one .  As you see the orig  retainer does not fit this ball. So there needs to be smaller retainer for this ball
« Reply #6 on: December 19, 2011, 07:52:28 PM »
AH! I see what you mean now. In that case that knob is in the wrong box!
plumL78
« Reply #7 on: December 19, 2011, 08:51:07 PM »
That might be what it going on here. The box is was opened and is dated 5-75 , Thanks
kerry
67ssrsl78conv
« Reply #8 on: February 05, 2012, 07:37:10 PM »
kerry, i have that exact ball with the threaded bottom but with no hole on the side. i believe production cars originally came with this ball and gm changed to the 2-piece because it kept stripping. my l78 originally came with the i piece ball.
plumL78
« Reply #9 on: February 08, 2012, 01:15:35 PM »
I have an old orig big block shifter that has the two piece knob. The ball in the pic. is from that shifter If they ever came one piece and then switched over you would think your L78 car would be the two piece because of it being late production car . Maybe it was simply a supply issue. If they didn't have one they used the other
JoeC
« Reply #10 on: February 08, 2012, 02:34:13 PM »
I have not seen that ball before but I have had some Muncie shifters that had a chrome lock nut on the thread but no ball was there.
It is a thin nut and is chrome so its not a hardware store nut.
I don't think the two piece ball used a nut so always wondered why the nut was still on the thread.
I thought they were from an aftermarket ball but maybe that ball came with a nut before the two piece design?
not sure
I have seen some black one piece balls (I think GTO) but they were 3/8-16 thread not 5/16-18
Stingr69
« Reply #11 on: February 08, 2012, 04:39:35 PM »
I saw a simmilar crappy looking black small plastic ball come out of a GM parts box back in the 80's. Bob Harris was trying to tell me that this ball was the current service replacement. It was FAR from production line quality. GM service part or not there was NO WAY would I have that on my car.
-Mark.
