Author Topic: Can anyone help me Identify this Gm Piston?  (Read 8419 times)
Ramjett54
  • Decatur Alabama
« on: December 16, 2011, 05:24:49 PM »
I have 8 NOS domed pistons with two eyebrow valve reliefs, its 4 inch bore, 3 in stroke (302) has a GM # stamped on the top 39217624 and TRW cast on the inside below the wrist pin also has 3 cast ribs on both sides of the skirt.
Can anyone shed some light on what these are?
Re: Can anyone help me Identify this Gm Piston?
« Reply #1 on: December 16, 2011, 05:43:59 PM »
Sounds like the '67-'68 Z/28 piston, which used pressed pins with no grooves in the pin bore for retainers.
Ramjett54
  • Decatur Alabama
« Reply #2 on: December 16, 2011, 06:14:34 PM »
Your correct, no grooves. Can you tell me where you got your information?
Thanks again
Merry Christmas
« Reply #3 on: December 17, 2011, 04:34:09 PM »
Thanks again
Merry Christmas
Many years of experience - GM only made two 4"-bore 3"-stroke pistons; the one you have for '67-'68 302's, and the one in the photo below with a straight-across relief for the valves, floating pins, and grooves for pin retainers, used in '69 302's; it has 3927172 forged into the underside of the piston crown.
rodent
« Reply #4 on: December 17, 2011, 08:28:30 PM »
This piston is out of my '68 05A Z,part #3927172
« Reply #5 on: December 17, 2011, 08:49:13 PM »
The change to the '69 style piston was made during the '68 model year as noted in Jerry's book.
Ramjett54
  • Decatur Alabama
« Reply #6 on: December 18, 2011, 12:02:52 AM »
Is the latter style better than the early style, and if so, how and why?
« Reply #7 on: December 18, 2011, 06:53:48 PM »
Chevrolet must have thought it was an improvement, or they wouldn't have spent the money to re-tool it; the straight-across valve relief formation probably improved flame-front propagation.
