Author Topic: L-82 vs LT1 Which would be better for my project?  (Read 13951 times)
69Z28freak
« on: December 05, 2011, 08:43:20 AM »
I am building a 69 Z 28 clone. I am looking to do it on a budget if possible. I would like the car to apprear correct for the most part. I am open to suggestions of all types. Motor will be dressed stock 302 for the most part. No overly concerned with the internals. I would also like to build something that will give the project as much value as possible. I am not looking for a money pitt project. Looking to spend wisely, get as much performance as possible for a weekend driver. will have a Muncie M20 Trans, 342 373 or 410 rear gear, Chambered exhaust.
Which is the better motor combo for my project. I am looking at a few different motor options. I want to make sure I buy the right set up for maximum value and quality.
This L-82 is an original bore Corvette motor. Currently a short block. Needs to have cam and heads installed. Heads are 492 Angle plug or 186. This motor would be oil pan to intake. This package would cost $2500.00.
The other option is this 1970 LT1 same angle plug 492 heads or 186 heads. Oil Pan to intake, except blanced & blueprinted. $4000.00.
Which one is the better deal and better way to go for this project?
Mike 1969 Grandma Camaro
Kelley W King
Re: L-82 vs LT1 Which would be better for my project?
« Reply #1 on: December 05, 2011, 09:45:47 AM »
LT1
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
Dusk_Blue_Z
« Reply #2 on: December 05, 2011, 12:44:17 PM »
Make it a 'real' Z28 clone and put a 302 in her :)
1969 X77 01B 51 51 flat hood
« Reply #3 on: December 05, 2011, 04:45:57 PM »
I'd stick with 186 heads - angle-plug heads were never used on any production engine, and stand out like a sore thumb if you want it to look correct.
Stingr69
« Reply #4 on: December 05, 2011, 05:03:08 PM »
I would consider using the LT-1 for a clone project. Same sound and idle, better torque, solid lifters, EASY to find the pieces. Big reliable power. What's not to like about that?
L82 with small chamber heads is a darn good mild HP engine. I have one myself in my Vette. But this is a HYDRAULIC LIFTER cam!!! NO WAY does it belong in a first gen Z/28 clone.
JMO,
-Mark.
69Z28freak
« Reply #5 on: December 05, 2011, 08:20:27 PM »
Thanks guys good feedback.
L78 steve
« Reply #6 on: December 31, 2011, 03:29:29 AM »
The only difference between the two is The solid lifter cam/Holley/high dome piston on the LT1 and Hyd. cam/flat top piston and Rochester on the L82. Both are 4 bolt main blocks with high nickel content, Steel crank,Pink rods,2.02 intake 1.60 exhaust valves. Great bottom end with the L82, Improved hi RPM with the LT1.
69 Z/28 Dover White. SOLD
69Z28freak
« Reply #7 on: January 01, 2012, 01:54:36 AM »
Both motors would use the same carb Holley 650 DP, stock LT1 intake, and either 492 Angle plug or 186 heads.
69z28302
« Reply #8 on: January 01, 2012, 02:25:46 AM »
L-82 flat top would run great on the street. Picking your cam is very important. Just my 2 Lincolns worth.  ;D
tom
    • Discount Internet Services
« Reply #9 on: January 01, 2012, 06:59:19 PM »
Your looking for bang for your buck. Not what you asked, but I would lose the chambered exhaust for a better performing & less expensive aftermarket exhaust with original looking tail pipes.
69 X11 Z21 L14 glide
o
69Z28freak
« Reply #10 on: January 02, 2012, 08:15:54 AM »
Chambered exhaust is used off a buddys car, so it is cheap with headers.
