Author Topic: 1969 protecto plates  (Read 9025 times)
frankk
« on: November 23, 2011, 02:56:42 AM »
Was there a position on the propecto plate in 69 to designate the JL8 option? Where would it be on the plate using the grid shown on CRG. Thanks
Re: 1969 protecto plates
« Reply #1 on: November 23, 2011, 03:19:35 AM »
Yes, it would start at row B, column 15, and continue through column 21.
HERE'S more info on POP decoding, and HERE'S the list of axle codes. (NOTE: If the table is blank on your screen under the "1967-1969 Camaro POP Option Fields" heading, just click, hold and drag your mouse in the table and it'll all show up. It's a bug in IE.
frankk
« Reply #2 on: November 23, 2011, 05:02:59 AM »
Ed that position is filled by the rear end code and date. None the less, looking at all the info on my plate I see now there is nothing to designate JL8 brakes.
« Reply #3 on: November 23, 2011, 10:13:44 AM »
Quote
That's correct. That's the only place on the POP that will tell you if the car originally came with 4 wheel disk brakes.
frankk
« Reply #4 on: November 23, 2011, 05:54:41 PM »
So Ed if the POP shows the rear coded for a JL8 rear, does that then confirm rear discs? So no separate coding except for the JL8 rear? Correct?
jl8dale
« Reply #5 on: November 23, 2011, 07:42:50 PM »
The rear axle code is the only code to designate  wheel disc brakes on the POP.
What is the code listed on your POP?
1969 Z/28 Daytona Yellow/Yellow Houndstooth, Tilt, Fold Down Seat, - POP
« Reply #6 on: November 23, 2011, 09:33:23 PM »
Quote
Correct.
« Reply #7 on: November 24, 2011, 12:07:53 AM »
Argh, I thought I had that fixed!!
« Reply #8 on: November 24, 2011, 02:29:57 AM »
Firefox works just fine, but not IE 8. Not sure about IE 7, 9 or the beta 10 (or Safari either).
frankk
« Reply #9 on: November 24, 2011, 03:55:19 AM »
Got it. Thanks Ed. Dale its a QY code.
jl8dale
« Reply #10 on: November 24, 2011, 03:59:57 AM »
That would be a JL8 car with a 410 rear axle!
« Reply #11 on: November 24, 2011, 05:40:28 PM »
Frank, if Kurt hasn't already asked, he'll probably be contacting you shortly about your car for the database!
