Author Topic: 69 L48/LM1 Automatic "Keep Your GM Car..." Decal Info Wanted  (Read 78417 times)
Re: 69 L48/LM1 Automatic "Keep Your GM Car..." Decal Info Wanted
« Reply #15 on: November 19, 2011, 05:40:33 PM »
http://www.angelfire.com/rock/69ss/frame.html
I didn't look.  See if this guy has any or knows?
69redrsss
« Reply #16 on: November 19, 2011, 06:49:44 PM »
I was looking into this issue earlier and found someone with 2 original Chevelle L48s and, although the air cleaner looks identical (except for the lid is black), the part number CM / 6484582 is not in the Camaro parts books.  So the part numbers appear to be model and/or factory specific.  This agrees with some of the parts catalogue info I've also stumbled upon. Therefore I'm trying to concentrate on Camaros only.
The attached TC post for a 69 RS shows the black 6484584 decal like the one shown.  I'm assuming it was also from an L48 as his lid is chrome. I've yet to hear what the build date of his car is but is was a powerglide which might suggest an earlier build than my August 69 car.
http://www.camaros.net/forums/showthread.php?p=1627945
I will try to downsize the copies of the parts catalogues I have so I can post it for everyone's reference.
« Last Edit: November 19, 2011, 07:30:27 PM by 69redrsss »
Les
'69 Garnet Red TH350 SS350 RS
69redrsss
« Reply #17 on: November 21, 2011, 06:18:15 AM »
Not great quality but here are the catalogue pages
Les
69redrsss
« Reply #18 on: November 23, 2011, 02:57:28 AM »
A summary of the previous attachements.  I can't find the manual transmission air cleaner part number in the AIM.  If others have found it please let me know where.
1969 350 L48 Air Cleaners
                    AIM UPC    AIM P/N   AIM Comment        Jul 69 Cat   Dec 72 Cat
Non-Cowl Induction
Manual          L48 / A2      Note 1        6484583     6484583
Auto              M35/A22  6484584   RPO L48 & LM1                                                               6484584     6484584 Note 2
                    M38/A2        "          6M-3 Air Cleaner & Silencer - Assembles the same as M35   Note 3       Note 3
Cowl Induction
Manual          ZL2/A3     6485233   RPO L48        6485233    6485233
Automatic      ZL2/A3     6485234   RPO L48 with RPO M35 or M38                                         6485234    6485234
Notes
1. AIM refers to L65 but L65 is only a 350 2BBL
2. Also 6485252 with 2" vs 1-1/2" heat stove in 1972 catalogue
3. AIM & Camaro Master Parts Catalogue do not differentiate between PG & TH350 350 4BBL automatics
Les
Steve Shauger
    • Vintage Certification
« Reply #19 on: November 24, 2011, 02:05:55 AM »
The two letters are C O and the part# is 6484584 for L48 auto.
Steve Shauger
69redrsss
« Reply #20 on: November 24, 2011, 04:03:13 AM »
Thanks Steve. You may be correct but without a good picture of one it's tough to convince a reputable reproduction company to make one up.  Have you got one & a picture (with dimensions) you can send me?  The two letter code should be on your broadcast sheet if you have it.
Les
Steve Shauger
« Reply #21 on: November 24, 2011, 04:50:43 AM »
See picture below.The car is stored but I maybe stopping by to work on another car.
Steve Shauger
69redrsss
« Reply #22 on: November 24, 2011, 05:25:23 AM »
Excellent Steve!!!  When you get a moment could you get a hieght & width measurement for me? That would be great.  I assume that it is a pretty standard decal but it's one thing Osborn wanted to know before they would even consider reproducing.  I appreciate that there is a little wear on the decal but does it look layout & color wise the same as the reproduction I showed earlier for a L48 Chevelle?
Les
z/27 camaro
« Reply #23 on: November 25, 2011, 08:37:06 AM »
anyone got an idea what the Letter code would be for a L 48 auto with ZL 2 cowl induction? we have the part number as posted by Les.......6485234
i was previously under the impression that the proper decal for any ZL 2 cowl induction car would be a DG 6485235.
« Reply #24 on: November 25, 2011, 03:53:38 PM »
L48 auto would be DF.
Oaklyss
« Reply #25 on: November 25, 2011, 04:05:58 PM »
ZL2 Air cleaner code for L48 manual is DE 6485233 (this is would I have, The DE is also shown on my Chassis Broadcast Copy)
ZL2 code for L48 automatic is DF 6485234
ZL2 code for L34, L35, L78 Z/28 is DG 6485235
69 RSSS ZL-2 4 speed, mint unrestored 04A LA built-SOLD
1968 GTCS mint unrestored original paint
1972 AMX 401 4 speed, cowl induction, twin-grip, A/C, unrestored, original paint
1963 Oldsmobile Jetfire factory Turbo and Methanol injection, 4 speed, posi, 1 of 4 known to exist
« Reply #26 on: November 25, 2011, 05:22:10 PM »
The sticker that I posted is off of a Jan 69 built car.
Steve, what's the build date of that car?
Steve Shauger
« Reply #27 on: November 25, 2011, 10:13:42 PM »
The picture is from my 04C built NOR car and another car with the same sticker is 03B.
Steve Shauger
z/27 camaro
« Reply #28 on: November 27, 2011, 08:53:00 PM »
thanks for the info Oaklyss and william.....interesting that the code and part number is the same for the ZL2 ...L34, L35, L78 Z/28 ... DG 6485235 and its different for the ZL2  L 48.
« Reply #29 on: November 27, 2011, 09:54:33 PM »
The L48 auto ZL2 air cleaner assembly is unique in that it has the valve in the snout for the exhaust manifold pre-heat. Not reproduced and hard to find.
The 350/manual unit is somehow different than the 396-427-Z/28 unit; don't know why. Needs a side-by-side comparison.
