Author Topic: 1969 z/28 clutch pressure plate  (Read 7474 times)
asm69
« on: June 18, 2006, 02:06:15 AM »
Where can I find the casting number or part number or build date on the clutch pressure plate.
Are there any numbers to be found on the clutch disc.
Re: 1969 z/28 clutch pressure plate
« Reply #1 on: June 19, 2006, 12:00:10 AM »
Chances are slim to none that it still has the original GM clutch in it, and the aftermarket clutch manufacturers all have their own methods of marking pressure plates and discs.
asm69
« Reply #2 on: June 19, 2006, 03:12:13 AM »
The clutch disc itself has GM stamped on the rivet heads. But, I cannot find any identifying
numbers on the clutch pressure plate. It would be nice to know where GM stamped
or cast the numbers on the pressure plate.
Thank you
« Reply #3 on: June 20, 2006, 01:02:23 AM »
GM didn't manufacture their clutches - they bought them from an outside supplier.
