Author Topic: Can anyone tell me if this fender is real or reproduction ?  (Read 15864 times)
ScottJon
« on: November 09, 2011, 04:18:55 AM »
Hi
I was told that the fenders on my 69 Camaro may be reproduction based on the screw tabs in the photo
is this true?  how can i tell for sure?
the reason for this is because there are no associated screw tabs to match against them on the grille
ANY advice here is welcome
Happy 1969 Z28 owner guardian
LM69Z28
Re: Can anyone tell me if this fender is real or reproduction ?
« Reply #1 on: November 09, 2011, 05:14:25 AM »
You may have scored Rally Sport fenders? but I'll leave that to the guys in the "know"
Good luck
LM69Z28
ScottJon
« Reply #2 on: November 09, 2011, 05:18:13 AM »
you know i hadn't thought about that
my car is a Z28 with standard grille
it was made in Los Angeles in May of 1969, so anything is possible
KevinW
« Reply #3 on: November 09, 2011, 05:35:03 PM »
Those are not RS fenders, the RS extensions are much larger.  In order to find out whether they are repro, you need to look at the nutserts that hold the hood hinge on.  repros are just flat metal with a hole and a nuts welded on the inside.  factory fenders had a square nut attached in a recess.
ScottJon
« Reply #4 on: November 09, 2011, 05:47:09 PM »
this clears up a lot
so let me ask my dumbass question if you will ?
would that explain a 1/2" gap on either side of the standard grille i have on my car?
meaning, is the standard grille not as wide as the RS grille?
What I am thinking is to change the fenders then to a set designed for a standard grille?
I dont know if my Z was a RS when it was born or not, but changing the fenders before we paint the car sounds like a less expensive, and probably more accurate representative of what the car should be
« Reply #5 on: November 09, 2011, 07:00:47 PM »
Those are not RS fenders, the RS extensions are much larger. .
jl8dale
« Reply #6 on: November 09, 2011, 07:18:48 PM »
Those tabs are for the headlight buckets, not the grille.
Here is a pic of an original GM fender. Notice the double sheet metal at the tabs.
If yours does not look like this, I would assume repro.
1969 Z/28 Daytona Yellow/Yellow Houndstooth, Tilt, Fold Down Seat, - POP
ScottJon
« Reply #7 on: November 10, 2011, 02:37:10 AM »
were there different fenders for RS vs Standard? or just the Grille?
the problem with my car is that there is a 1/2" gap on both sides of the grille inside the nose of the car
Im trying to determine if it is the grille or the fenders
mark x22
« Reply #8 on: November 10, 2011, 03:08:43 AM »
Put the grille back in and take a picture . your fender is for standard grille and looks damaged on the top corner . This is a RS fender .
« Reply #9 on: November 10, 2011, 04:11:41 AM »
Here's pics of RS and non-RS 69 OEM fenders.
http://www.camaros.org/options.shtml#rs
ScottJon
« Reply #10 on: November 10, 2011, 04:18:06 AM »
Kurt, your a rock star
thank you
everyone is so great here, i only hope i can help you guys some time too
jl8dale
« Reply #11 on: November 10, 2011, 02:27:55 PM »
Here's how the grille should look seated in the fenders.
ScottJon
« Reply #12 on: November 10, 2011, 04:44:46 PM »
Awesome the fit and finish is great
and I love the color,  mine will be back to brown soon
frostCamaro
« Reply #13 on: March 07, 2012, 08:04:44 PM »
I've read in another thread about the hinge bolt area. Could somebody post a picture?
"the threaded holes for the hood hinge etc. are rectangular nuts pressed into the holes. They are "T" shaped so they won't pull through"
That's what I read in another thread.
« Reply #14 on: March 08, 2012, 07:25:46 AM »
Ok Mr Frost Camaro,  I tried to take some pix of the captive nuts on the fenders, but I have both an OEM and Repro fender extension which was easier, and the type nuts used are the same as for the fenders.
OEM nuts, from outside and inside (square holes in fender):
Repro parts nuts, from outside and inside (round hole in fender):
Gary   /  69Z28-RS
